Question about EnGenius EOC-3220 (EOC3220)
Trying to get into my engenius 3220.using 192.168.1.254
Cannot get into my bridge with 192.168.1.254
  • 44ellados Apr 29, 2009
    Get a message saying my LAN is conected, but cannot get any internet connection using 192.168.1.1 or 192.168.1.1
  • 481 Answers
If you have lost track of what IP address you have assigned your 3220, you can use the serial reset procedure documented here to return it to factory defaults:
http://www.engeniustech.com/datacom/support/general-details.aspx?id=65
Posted on Oct 28, 2009
3 Suggested Answers
redhaze89
  • 854 Answers
SOURCE: unable to open engenius 3220 with 192.168.1.10
it's not possible. hardware not match
Posted on Aug 13, 2009
Macs R We
  • 481 Answers
SOURCE: cannot get in to my Engenius 3220 with 192.168.1.10
Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping 192.168.1.10. If it answers, browse to 192.168.1.10 and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, 192.168.1.10 is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
If the ping and browse succeed, then make sure that 192.168.1.10 is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
Do I need to change the password on this product if the password for my wireless network is changed?
I am assuming you are using it as a wireless bridge to connect wired devices to your wireless network. If that is the case, then yes. You must change your key on all wireless devices (including your bridge) if you change the key to connect to the access point.
Oct 29, 2010 | EnGenius ECB-3220
We have a probleme whit engenius 3220 in security set web key and what is the encryption key 1, key 2, key 3 , key 4. If we change web for none in security we have a default encryption type mismatch...
If you really wish to use WEP encryption, you should enter your WEP key in the key1 field. However, WEP is weak and breakable in under four seconds. I would recommend using the WPA encryption instead, with a passphrase. The AES mode is strongest, but the TKIP mode is compatible with more and older machines.
The reason you are getting "default encryption type mismatch" is because the encryption type has to be set exactly the same on the AP side and on the bridge side in order for you to communicate. When it is not the same type, you get this error. If it is the same type and you just have the wrong password, the error will be different.
Sep 11, 2010 | EnGenius EOC-3220 (EOC3220)
Data communication problems accross my WLAN Bridge
The first step here is to identify exactly what portion of the link is the culprit. Clearly you must have some sort of AP in the remote building for the handheld devices to connect to, since the bridge radio won't perform that function. So I would attach an AP of that type directly to the ProCurve and see if the problem is present or absent when you try to sync devices using that AP without any involvement by the Engenius units at all. If you isolate the behavior to the Engenius units, you may have to play with the Data Rate and Fragment Threshold settings.
May 11, 2009 | EnGenius EOC-3220 (EOC3220)
Cannot get in to my Engenius 3220 with 192.168.1.10
May 02, 2009 | EnGenius EOC-3220 (EOC3220)
Username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
I am using a EnGenius Senao 3220 plus bridge radio to pick up the signal from another same brand radio. i am able to connect to the network but i was not able to get in to the internet: "Unable to get...
If you have the radio configured as a bridge (not a bridge-router), you must ensure that your computer is in the same LAN IP subnet as the remote router. If the remote router supplies DHCP, this should happen automatically; if not, you must configure your computer manually.
Once there, you may have to manually define DNS servers on your computer in order to access machines on the internet by name. If you can browse to http://216.239.122.34, but not to http://google.com, your problem is solely lack of defined DNS servers. This is not an artifact of the Engenius units, but the remote server.
Oct 31, 2008 | EnGenius EOC-3220 (EOC3220)
Eoc3220+ ip finder
hi
reset your eoc 3220 and put the default ip address is 192.168.1.254 bridge mode and ad mode ip is 192.168.1.253 and put your pc ip 192.168.1.10,12,14,16 and open the web page and browse the 192.168.1.254 or 192.168.1.253 put user name and password ok!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct 07, 2008 | EnGenius EOC-3220 (EOC3220)
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
Change mode
what and how r u doing it?
Dec 05, 2007 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
387 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
