Question about Black & Decker 11-3/4" Navigator General Purpose Blade
Need help putting the blade into a black & decker power hand saw
  • 1 more comment
  • hotdan Apr 25, 2009
    I am unable to replace the blade in a black and decker navigator saw. It just wont go in.
  • jtkoziol May 18, 2009
    You are amazing!! I spent lots of time trying to find this information. Truly appreciate your answering my plea for help.
  • David Ford
    David Ford May 11, 2010
    what model number we talking about and I will try to help
  • 2,176 Answers
Go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number and it will go to a page where you can download the instruction manual or view it online on how to remove and install this blade. If I have helped you with this would you please rate my solution accordingly and thank you.
Posted on May 18, 2009
  • Barrie Lee Sep 05, 2013
    Thanks David for your help .Tried it but didn't work for me
  • Dori Snody
    Dori Snody Oct 13, 2013
    Looked at the instruction manual but cannot figure it out either. I have no idea from the instructions how to turn the locking pin in order to have the blade fit on it. Any ideas?
Can you fix a broken control knob
Contact Black and Decker for the best info.
Putting the wrong blade in shouldn't affect the knob.
Jun 10, 2015 | Black and Decker USA Wood Cut Jig Saw...
Need to replace a miter saw blade on Black & Decker saw
If you don't have a manual, you can contact Dewalt, and they will get you one or help you. UNPLUG THE SAW!! , if your saw has a blade lock, engage it, if it doesn't hold the saw firmly on a scrap piece of wood. Then use the correct wrench and loosen the retaining nut. Take the nut off, remove the blade
Feb 24, 2014 | Black & Decker Saws
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
I have a Black and Decker KS555 circular saw and
It appears that you have adaptors for the blades that are the same thickness as the blades Place the adaptor in the centre and then put on the spindle and tighten up the plates onto the blade.
Sep 05, 2013 | Black & Decker Tools & Hardware - Others
Looking for replacement blades for Black & Decker Zip Saw
Its on ebay http://www.ebay.com/itm/NEW-BLACK-DECKER-ZIP-SAW-11-PIECE-CUTTING-SET-74-691-/260888941452
only 15.00
Apr 02, 2012 | Saws
Black & decker 10" table saw -where is the blade
The Blade is held on by A Nut and Washers. Remove the Blade insert and you should see the nut and washer
Jun 26, 2011 | Black & Decker Saws
Black & Decker Blades
the blade jig saw does not stay in on black &decker js2500
Mar 07, 2010 | Black & Decker Scroll Jig Saw Blade
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Black & Decker 11-3/4" Navigator General Purpose Blade Logo
869 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
