Question about Frigidaire GLEQ2152ES Electric Dryer
Power but no movement
The dryer has power, all lights go on, but when I hit "start" it doesn't move, just makes a low hum sound
  • ownersstable Apr 16, 2009
    I fixed it, followed someone's idea to spin inside 4-5 times each way and now it works..thank u
  • 77 Answers
Your belt is either off track or broken. Refer to your manual for routing of a new belt. 20 dollar fix. Good luck.
Posted on Apr 18, 2009
Frigidaire Gallery Electric Dryer, model GLEQ2170KS.
Can you tell if the dryer is moving air? Is it getting Hot?
if yes, then it sounds like a belt issue. If it is moving air, then the motor is running. If no air, then the motor is NOT running. If this is the case, I would not leave it "Humming" for long. Motor could get pretty hot. Also, there is often a one time over temp switch in the motor. If this gets too hot, this will trigger, killing the motor.
If it seems like a belt issue, look online for instructions for opening the machine up, and check the belt status. Belt could have jumped off a pulley, and just needs to be put back on. Or, something could have failed. You will have to look inside to find out more.
Jul 02, 2012 | Frigidaire GLGQ2170K Dryer
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
Dryer won't start. has power, lights are on, when I push start I just get a loud humming sound.
Try to turn the tub by hand, if it will not move or is real hard to turn, your motor may be locked down. They usually make a humming sound when you try to start.
Aug 28, 2010 | GE DPSB513BW Dryer
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
When I push the start button the dryer will not start
May need to replace the starter swithch behind the control panel. MAKE SURE ALL POWER IS DISCONNECTED. If you still hear a humming sound when you hit the start button then it is not the switch, but the motor and if that is the case you may want to look into your warranty.
Aug 16, 2009 | Kenmore 63942 Dryer
LEA30AW makes a humming sound when i hit start,
motor is most likely bad shorting out in the windings
Jun 26, 2009 | Amana NDE2335AY Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
89 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
