Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
Help me please..I can not see anything in my computer screen after I turned my cpu off due to the monitor display got flickr. My Mobo is asus p5gcmx and since one year ago it processor has been overclocked from 2000 mhz to 2400 Mhz. I got frustrated coz I can not reach the BIOS so I suspect that the mobo has been failed? Is that right? Please advice me....Thanks
  • harwadi Apr 16, 2009
    Thanks for ur reply Mr kamal1984, I'll try it.
    Dear Mr.Kamal1984, I have done as u suggested and it did't help me.. nothing appeared on my computer screen except the light on the power button of my lcd screen keep blinking. Any suggestions please....
    President:
  • 1,383 Answers
Ok
open cpu covers and check on motherbord u find cmos cell on it
It is round cell on motherbord
pull away it from motherbord for 15 minutes then refix it again then it reset to factory defaults.
Posted on Apr 16, 2009
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
ASUS monitor is plugged into MacBook Pro. Has worked fine over the last 12 months with both screens working independently. Recently unplugged for 2 months. Plugged ASUS back in. After approx.5 minutes, the...
(1) If you have connected windows cpu to monitor then when you power up the computer press F8 key then enter in enable vga mode then go to control panel ->display property -=>settings change screen resolution to 1024*768.
then check .
(2)But if you are not able to see any display on screen then open cpu cabinet and refix ram memory pull cmos cell from motherboard for 10 minutes ,if there is any pci card or vga card installed on motherboard reattach it into motherboard.Then check.
If you have mac book then follow my second solution.
Let me know if you need further assistance.
Thanks for using Fixya.
Apr 07, 2010 | Computers & Internet
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
Asus p4p800s-x won't boot and no display on the monitor..
get a better power supply, as i understand it, youre computer is getting too little power from it. pick a power supply with more volt
May 28, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
ASUS P5KPL-AM CPU fan connection.
You should still be able to connect the 3 pin connector of the fan to the 4 pin connector on the mobo, the keying tab is offset so that you cannot connect it to the wrong pins.
If you still don't want, or can't connect it there, simply go on the Bios (press delete after you turn on your computer) and you will find an option to monitor CPU fan speed.
If you need any more help, let me know
Alex
www.CAS411.com
Mar 28, 2009 | Computers & Internet
Dont suit my mobo
remove the graphics card, turn the computer on, wait for any error beeps if any, then re-install the card , then try it again, this should work, hope this helps you,glen.
Dec 21, 2008 | ASUS A9550GE/TD Radeon 9550 Graphic Card
Computer won't turn on.
This sounds like an overheat problem, is your cooling fan working properly, also the processor you are using is a powerful one, so needs a cooling fan much more powerful than the lesser powered athlon 64 processors.
Dec 02, 2008 | ASUS CROSSHAIR Motherboard
ASUS P4SP-MX motherboard no POST and no beep without ram
Try removing everything attached to it. The only thing should be the cpu and cpu fan. Turn it on. If it is the same, then it is your motherboard. If you do get the beeping, then start installing things one by one starting with the memory.
Jul 03, 2008 | ASUS P4SP-MX Motherboard
Pc turns on but no display on monitor
hi, need some help. when i turn my computer on i have lights and fans working, no beeps and no display.monitor is working fine with another comp. any ideas? thanks ... hawkeye.
Mar 14, 2008 | Jetway (MINIQ 860TWIN) Barebone
Asus P4S8X-X - Pentium 4 - 2.4 GHz
I would try another Power Supply Unit.. are you sure it's the PC and not the monitor thats faulty? You could check this by connecting another monitor,and see if it does the same...
Dec 19, 2006 | ASUS P4S8X Motherboard
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
136 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
