Question about InFocus ScreenPlay 4805 Multimedia Projector
Picture My picture has a yellow line down the right side. I exchanged the lamp, but still have the same problem.
  • RYLEY1 Nov 07, 2007
    YELLOW LINE ON RIGHT SIDE OF SCREEN AND SOME NOISE OUT OF UNIT SOMETIMES
The light tube has collapsed..there is a repair for this
Posted on Nov 07, 2007
Yellow line down one side of mp 8749 projector
the LCD panels is defective
replace it with a new one
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
http://www.lampdeng.com
Feb 27, 2014 | 3M MP 8749 Multimedia Projector
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
Line down middle of the screen-resolution is different on sides
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
Jul 07, 2009 | LG Computers & Internet
YELLOW AND BLUE SQUIGGLY LINES ON THE RIGHT SIDE OF THE SCREEN
Hi Fkanode.
The failure(s) in your TV is related to a part called light engine or optical block and Sony TVs are known for these kind of failures with the video showing with different colors or lines.
Check the link provide for more info or if you would like to try fixing the TV yourself.
Let me know if you would need further assistance.
Mar 07, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi tv model wd 73727 and how to take tv apart to clean marrow
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
Rick
Woodland Hills, Cal.
Apr 12, 2009 | Televison & Video
Sharp LC-32D43U
This unit probably has a bad power supply. It may also be shutting down because if this unit has recorded 5 lamp errors it goes into shut down. To eliminate lamp errors you can force the unit on in the service mode and look for lamp errors. To do this, you unplug the unit, and while depressing the volume up and channel down buttons at the same time, plug the unit in. Hold for 1 second and release. The unit will then power on and a small k should appear on the screen. If this does not happen then there is definately an internal failure that will require a sharp auth. service center. If the unit does come on with the k, use the remote and press the channel up button. This will produce a menu on the screen and you will note on line will indicate lamp errors. On the right side of that line will show the # of lamp errors. If it reads 0, lamp errors are not the issue, however if it reads 5, you can highlight that line by using the channel down button. Then use the curser right arrow to select the error and then again to reset them. Once the lamp errors have been reset to 0, unplug the unit and wait at least 25 seconds before plugging in. The unit will now power up normally and this may cure the problem for good. If this process corrects the problem and it occurs some time later or right away that will be an indication that either the unit has bad backlights or inverter has failed and will again require service.
Feb 07, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
InFocus ScreenPlay 4805 Multimedia Projector Logo
152 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
lekmai
lekmai
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
