Question about RIM BlackBerry Bold 9000 Smartphone
Unknown icon an icon appeared at the top center of my blackberry bold screen a few weeks ago and the 3 techs i've talked to don't know what it means. it is a rectangle that is outlined in a thin white line; there are 5 white outlines of diamonds that go from the upper left hand corner down to the lower right hand corner in side that rectangle. it only appears when i use the phone and i think when i go on the internet too. i would love it if you could enlighten me
  • richyrich666 May 07, 2009
    I also get a white box with 5 stars in it when I make calls any idear what it is and how to stop it
  • pegasus1128 May 11, 2010
    If you could e-mail me a picture of it I might be able to get it figured out for you. pegasus1128@gmail.com
    Problem Solver:
  • 9 Answers
I had the same problem for awhile too.
The box is your call equalizer settings.  The descending line indicates "boost bass" and the ascending line indicates "boost treble"
This usually only shows when you have your BB headset connected, to change the settings:
-plug in your headset -make a call, (voice mail works good for this) -press your menu button -select "Enhance Call Audio"
-make your selection
You'll see your choice on the screen
Let me know if this helps 208E019D
Posted on May 09, 2009
I have a Blackberry Bold The lock icon is on the bottom right but then it goes topassword. I've tried what I think the password is but no luck. I don't remember it. What do I do to get it?
There is only one option left to unlock your blackberry phone, but it will erase all your previous data. Type any password until you fail 10 times, it will make your blackberry bold unlocked from old password. You can try other option to unlock blackberry but the result will be same, you can't save your data, that's feature of RIM security system. Sounds like double side sword huh?
Jun 02, 2011 | RIM BlackBerry Bold Smartphone
I have a blue icon with dots on it at the top of my the phone in the middle of the screen. How do i get rid of it?
It sounds like the Blackberry Messenger Icon which means you have messages in Blackberry Messenger. To get rid of the icon you simply have to go read the messages. This is the only icon i can think of that is blue with white dots that would be on top of the screen.
May 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
Bb 9550 getting 365 error what can i do to fix it?
App Error 365 is a software error, most often related a theme or third party application you've installed.
Follow these directions:
1) Make sure you have Blackberry Desktop Manager installed.
http://us.blackberry.com/apps-software/desktop/
2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks):
"c:\program files\common files\research in motion\apploader\loader.exe" /nojvm
3) The Application Loader Wizard will appear -- click "Next."
4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button.
5) You should then see a list of applications ready to be installed for your Blackberry. Hit Next and Finish and you are well on your way to getting your Blackberry back to life.
Just don't disconnect anything and let the lengthy process finish completely.
NOTE: If you do not see a list of applications mentioned in step 5 and instead see the message "The Blackberry Desktop Software does not have Blackberry Device Software for the device that you have connected to the computer. Contact your wireless service provider or system administrator," then you must download Blackberry's Operating System for your carrier and device.
http://www.blackberryfaq.com/index.php/BlackBerry_Operating_System_Downloads
Just select the appropriate carrier and network type, select your Blackberry model from the list and download the latest version. Install this download and follow the above steps again and you should be on the right path.
I hope this helps.....
Good luck
Apr 30, 2011 | RIM BlackBerry Bold 9700 Smartphone
Mi bb 9700 mostro error 523 y no lo puedo utilizar necesito ayuda gracias
App Error 523 is a software error, most often related a theme or third party application you've installed.
Good luck
Apr 29, 2011 | RIM BlackBerry Bold 9700 Smartphone
My blackberry bold 9000 led stays red for a few seconds and then shows the charging icon then cycles back to the red light. It won't turn on.
It can be deduced from your problem that there is an error on the operating system of your bold 9000,I also use a bold 9000 and i experienced the some problem 2 wks ago,
This solution helped me out;
1.You have to do a hard reset on your bold,which means you have to remove the battery from your phone and re-insert it back after 10mins,
2.if the above solution doesn't work,it means you have to flash the entire ROM random operating memory of your phone,which requires the use of a particular software which can be got from any phone technician in your area.
Have a nice day.
Jun 27, 2010 | RIM BlackBerry Bold 9000 Smartphone
I want the unlok code of my blackberry 9700 bold
There are two methods for unlocking Blackberry Bold 9700 by MEP number and by IMEI#.
The simplest method for unlocking by IMEI#.
You can find your Blackberry Bold 9700 IMEI number by follow one of these steps.
1.By Pressing *#06# into the phone.
2.On your Blackberry cell phone, go to Options-->Status.
3.put the battery out,there should be a white sticker it will show your Blackberry IMEI #.
This Blackberry Unlocking codes provider provides unlock code for Blackberry Bold 9700.
Hope this helps.
Jun 25, 2010 | RIM BlackBerry Bold 9700 Smartphone
Folks can't hear me when I talk on my blackberry bold but I can hear them. This as only started since I connected with my bluetooth device. Any suggestions? The phone is only 3 months old
This could be caused by a software error in which the phone still thinks the bluetooth is still connected and is still being used as a microphone you can try a couple things here: 1. go to your bluetooth device list on your phone and delete the device 2. try to connect and then disconnect the bluetooth device and see if that returns everything back to normal 3. when you are calling or get called select the blackberry menu which is basically the blackberry icon on the keypad and go and find the option activate headset or something close to that which should activate the speaker on phone which you use for your ear.
I hope this helps,
Kyle
Jul 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
Lost my blackberry icon
For older Blackberry models you would need to do the following to show hidden icons:
From the main icon screen, press the alt key (an arrow should appear in the upper right corner), press the right track wheel in. The menu should appear in the lower left corner.
Mar 26, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry Bold 9000 Smartphone Logo
285 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
