Http://support.asus.com/cpusupport/list.aspx?SLanguage=en&p=1&s=22&m=P5VD2-MX&os=&hashedid=neVcvuSgEUZcO3rK
HERE DO YOU SE SUPPORTED CPU.
Testimonial: "of course its not on the list, what if i try to update the bios, do you think that e7600 will work on this board?"
SOURCE: problem restrart pc /NO AUTORESTART
The Core 2 Duo works fine with this board. You may need to flash the BIOS to a newer version for newer CPU type compatibility.
The 'Overclocking Settings Have Failed' message is an anomaly that I have seen on ASUS boards many times. It happens even when you are at default BIOS settings. It is most likely a Power Supply issue. Make sure your PSU is ATX 2.0 compliant. (Has the extra 4 connectors on the Mainboard power connector- not the extra 4-pin plug that feeds the CPU - the 24 pin main connector)
SOURCE: raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
SOURCE: p5ld2-vm problem
go to "bios settings" by pressing "delete" key or F2 at the system start up time .. after going in to bios then search for the options load optimal defaults ....then save it and exit ..
after that restart ...
now have a check if your problem persists then the processor which you have choosed might not support the motherboard specification the frequency of the processor is higher than the specified rate .. check here for the details of the processor which supports your motherboard
Intel Core 2 Duo
HH80557PG0332M
BX80557E4300
E4300
1.8GHz,800FSB,L2:2MB,65W,rev.L2
1102
2.00G
HH80557PG0332M
BX80557E4300
E4300
1.8GHz,800FSB,L2:2MB,65W,rev.M0
1401
2.00G
HH80557PG0412M
BX80557E4400
E4400
2.0GHz,800FSB,L2:2MB,65W,rev.L2
1202
2.00G
HH80557PG0412M
BX80557E4400
E4400
2.0GHz,800FSB,L2:2MB,65W,rev.M0
1401
2.00G
HH80557PG0492M
BX80557E4500
E4500
2.2GHz,800FSB,L2:2MB,65W,rev.M0
1401
2.00G
HH80557PG0562M
BX80557E4600
E4600
2.4GHz,800FSB,L2:2MB,65W,rev.M0
1401
2.00G
HH80557PG0642M
BX80557E4700
E4700
2.6GHz,800FSB,L2:2MB,revG0
1401
2.00G
HH80557PH0362M
BX80557E6300
E6300
1.86GHz,1066FSB,L2:2MB,rev.B2
0901
2.00G
HH80557PH0362M
BX80557E6300
E6300
1.86GHz,1066FSB,L2:2MB,rev.L2
1202
2.00G
HH80557PH0364M
BX80557E6320
E6320
1.86GHz,1066FSB,B2:4MB,rev.B2
1202
2.00G
HH80557PH0462M
BX80557E6400
E6400
2.13GHz,1066FSB,L2:2MB,rev.B2
0901
2.00G
HH80557PH0462M
BX80557E6400
E6400
2.13GHz,1066FSB,L2:2MB,rev.L2
1202
2.00G
HH80557PH0464M
BX80557E6420
E6420
2.13GHz,1066FSB,L2:4MB,rev.B2
1202
2.00G
HH80557PH0564M
BX80557E6600
E6600
2.40GHz,1066FSB,L2:4MB,rev.B2
0901
2.00G
HH80557PH0674M
BX80557E6700
E6700
2.66GHz,1066FSB,L2:4MB,rev.B2
check the website given below for details :
http://www.cpu-upgrade.com/mb-ASUS/P5LD2-VM.html
thank you
rate my solution
SOURCE: install 2003 service pack 2
i'm installing windows sever 2003 but i can't find driver of mainboard intel dg31gl (sound and audio). do the mainboard dg31gl support windows sever 2003?, how can i install ? Help me, please. what can i do if mainboard dg31gl don't support windows server 2003? my mail is [email protected]
