I have a 5 year old Midea aw60-982 washing machine. The spin and drain is not working. The wash and fill is fine. The Drain pump is not blocked. Elly Collaroy
SOURCE: washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
SOURCE: indesit washing machine fills up and starts cycle
Could be heater. Try machine on rince cycle.Not pressure switch. If mahine works on rince then chances are heater. But this should not affect spin
A Error E2 and E4 comes up as well. Elly Collaroy NSW
