Question about Refrigerators
Ice maker does not receive water to make ice.
  • airtom Apr 16, 2009
    Solonoid water valve is okay. Suspect water switch, as it is not closed, even at very low temperatures. Can you explain the function of this switch? My e-mail is airtom@att.net.
    Inlet switch, called "water switch" on my wiring diagram is okay. So is holding switch. Does it make any difference what the orientation of the small temperature transducer located under the ice tray is?Perhaps I may have rotated it 180 deg. as I reinstalled it.
  • 10,515 Answers
Hi airtron,
 It's a simple fix.
solution - defective water valve.
To check and to repair, follow the below link :-
http://www.popularmechanics.com/home_improvement/home_improvement/1276061.html
Any further help, let me know.
Thanks for using Fixya.
Do rate the solution.
Posted on Apr 16, 2009
  • 1 more comment
  • taran_2005
    taran_2005 Apr 16, 2009
    Hi airtom,
     Glad that you checked it so soon.
     Now,
    if we talk about switches.There are 3 different switches that might be in an ice maker.
    If any of the switches are not working, ice make would not be able to make ice.
    1. Shut off switch
    http://www.acmehowto.com/howto/appliance...
    2.Holding switch
    3. Inlet switch
    Any further questions, let me know.
  • taran_2005
    Yup,
      That might be the case as transducer controls the signals to switch. So, even a small fault in transducer would affect ice making.
     Try to play with transducer and check whether it affects the flow of water or not.
    Let me know once done.
  • taran_2005
      There is one more thing we need to check.
     Have you checked whether water dispneser worked properly or not?
     It might  be a case of bad module..
    Also, check one of the solutions offered by an expert
    Before you replace the water valve, I recommend some further diagnostic testing. The water line to the ice maker being dry does not always mean that you have a failed water valve.
    Disconnect electrical power to the refrigerator and check the wiring connections on the icemaker valve. Pull one wire and take a resistance reading on the valve. If it is open (infinite resistance), then the valve will need to be replaced. If the resistance reading matches the resistance reading of the water dispenser valve, then it should be good.
    Since you were able to remove the back of the refrigerator and find the water valves, I will assume that you are able to safely conduct some other diagnostic tests on the ice maker if necessary. If not, you will need a service technician to make some of the more advanced checks. Do not make any check unless you are completely confident that you can safely complete the test.
    If you suspect that the solenoid valve is good after making the above checks, leave the refrigerator unplugged and check the wire harness disconnect plug on the ice maker module in the freezer. If it is unplugged, it will not cycle and fill with water.
    Carefully check the fill line from the valve to the ice maker module for a clog or ice plug.
    The next check is more advanced. This step involves the use of a small jumper wire. You will need a 2" piece of 14 gauge insulated wire. Bare the end about 1/4" on each side. (NOTE: When you use this jumper wire, handle it only by the insulated portion. Touching the bare wire portion while jumping the contacts could result in electrical shock.) Take the front cover off of the ice maker module. Make sure that the bail arm is in the down position. Plug the refrigerator in so that is has electrical power. Hold the jumper by the insulated portion and carefully stick the bared ends of the insulated jumper wire into the test points T and H on the bottom right side of the ice maker module. The ice maker will begin to cycle. (If it does not, you have a bad ice maker module and it will need to be replaced.) After several seconds, pull the jumper out of the test points. The ice maker will continue to cycle and will energize the circuit to activate the solenoid fill valve. Check the solenoid valve to see if it is buzzing. If not, you may have a wiring problem or a bad ice maker module. If you are able to safely check for voltage, check for 120VAC to the fill valve. NOTE: Voltage checks on live wires are extremely dangerous. Only conduct this check if you are experienced in safely making these checks using the proper equipment (volt/ohm meter). If the valve is getting proper voltage and is not opening, you will need to replace the valve. You can also check the ice maker valve by disconnecting power and connecting the water dispenser valve wires to the ice maker side. Reconnect power and activate the water dispenser. If the ice maker water valve does not open, it will need to be replaced.
    These diagnostic tests should help you determine or verify the component failure that is causing your ice maker fill problem. If you need more help in resolving this issue, resubmit your question with additional details.
    Thanks.
    Once done, let me know.
I cant get water to the ice maker
If the solenoid that controls the water intake is not activated either because it is defective or is not receiving the voltage from the ice maker, no water will flow into your ice maker. Make sure that the line is also not clogged - not likely but .............
Jan 25, 2014 | Kenmore 25.0 cu. ft. TRIO Ice & Water...
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Why does the ice maker in my Frigidaire model# FRS6HR4HW1 refrigerator not receive any water?
Could be the solinoid valve that lets the water throuh to the ice maker. i I would check the coil on the valve for a curciut
Jun 19, 2012 | Frigidaire Refrigerators
The ice maker has stopped making ice. Can still receive water but no ice.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 01, 2010 | Frigidaire Refrigerators
I have a gs5shaxnb02 ice maker and it does not make any ice, i replaced the boards the sender and receiver and it still does not make any ice. Is the problem with the ice maker?
the ice maker is probley the problem but need to ck the water valve first if it bad ( no water ) if valve is ok ck to see if the water tube is iced over preventing the water to be delivered to ice mker . these are most common . mm
Jul 29, 2010 | Whirlpool GS6NBEXR Side by Side...
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice maker is not making ice
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
I don't recommend repair on this unit. Simple replacement. Try to find Ice maker kit @ local home depot or lowes that is same. You can buy whole kit for $50-$75.00.
Aug 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker issues
Replace the Motor Module on the ice maker. I had the exact same issue.
Jul 30, 2008 | KitchenAid KSCS25FKSS Side by Side...
Ice maker won't make ice no water to ice maker.
My GE side by side ice maker cycles but does not receive water to make ice cubes.
Barb Elliott
Apr 29, 2008 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
