Question about Sony SDM-HS95 19" LCD Monitor
My power button keeps on blinking an orange light, but it doesnt work.
The monitors power button, the one that you press to turn on the monitor, its flashing an orange light, on and off constantly and the monitor won't turn
  • 186 Answers
SOURCE: Blank Screen, Flashing orange power light...
1st Idea - Let's take a look under the cover. I'm not sure how tech savvy you are, but I'm sure you're pretty good if you have a soldering iron. Once inside locate the power supply section. See if you see any blown capacitors on it or any other boards. One obvious way is to see if they are bad is if they have bulging up tops. There could be some weak or bad ones that aren't popped up, but let's start from there. If there are any bad caps, they are dirt cheap price wise at an electronics shop. Keep me posted and let em know what you find. - Scotty
Posted on Apr 30, 2008
0 characters
1 Points
Hi, it seems I have a problem with my monitor. Usually it doesn't turn on when I boot (had to keep pressing the power button or the power cable) until it opens up. When it turns off by itself at...
It may have dying power suply due to bad DC filter caps, you will need to inspect that first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Capacitors kit: he can make you a set of caps for you.
Nov 02, 2010 | Hanns.G Corporation HW173D Monitor
When I turn my computer on the monitor stays off. I press the monitor's power button and the orange light above it goes off, obviously turning it off. I press it again and the light turns blue, the words...
the monitor is not getting any video information from your computer .. check the connection at the computer to make sure it is fully plugged in .. make sure the video card (if it has one) is securely in place ... make sure the monitor is actually plugged into the right connector .. you may have a bad video card or a damaged cable to your monitor .. you can plug the monitor into another computer to make sure its ok ..
Feb 28, 2010 | LG Flatron L1750S 17" LCD Monitor
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
Feb 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Power button won't turn monitor off?
ok,your monitor is in  a very simple problem.clean the control panel circuit of your monitor,or if it is not working replace the tact switch in your monitor.
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
Sony SDM-HS95 19" LCD Monitor Logo
Top Sony Computer Monitors Experts
Lala Alonsi
Lala Alonsi
ray gallant
Are you a Sony Computer Monitor Expert? Answer questions, earn points and help others
