Question about Mitsubishi VS-50501 50" Rear Projection Television
MISTUBISHI VS-50501A - top 3/4 of screen displays ok, rest does not
Hi - 10 year old tv...has worked very well. Seldom used in the past two years (under one hour a week). Turned on TV and to 1/4 displays perfecty fine. Image - sound etc Bottom 3/4 is blank. I haven't been able to do much in terms of troubleshooting, but figured I'd post
  • 1 more comment
  • dicktrickle Sep 15, 2007
    Uploaded photo of problem...
  • orko512 Dec 29, 2007
    Having same problem. Did you ever get it figured out?
  • Anonymous Apr 01, 2008
    i have a mitsubishi vs-50501a. It had a coolant leak being moved. was moved on its side,not upright. i cleaned the coolant off the boards,but do these need replacing?.after the set is on for a while and i select menu ,the screen seems to get larger than goes back to normal. if i leave it on the guide plus screen long enough the set shuts off?any i deas?
    thanks
    kg
  • Mitsubishi Master
  • 8,617 Answers
Check the vertcle yoke pins for solder cracks. Check verticle output circuitry resistors and transistors. And also check for Coolant leaks from the CRTs this happens alot. Check capacitors for any signs of sweeling or heat as well.
Posted on Jan 04, 2008
SOURCE:
Acer Aspire ,5535 black screen,on/off button ok,...insert dvd searching??power light on, batt charging light on,fan on..where to go next
ok, 10 year old laptop
step1 , as always remove the old dead shorted huge battery first.
run now? it will on AC for every if you want.
Led Glowing tell not much its just and LED, so dont look at them if on, unless and LED blinks codes. ok?
what matters is power, power is first. no power no joy, ever.
so out the battery now.
Put in a new RTC coin cell battery next 7 year life rated you are 3 years past that at 10 years old, (end of useful life that)
next is fans, , ok fan is on.
next is what, TEXT got TEXT ON SCREEN>? ANY THING??
I guess ZERO SCREEN anything of any kind>.
we next use a flash light, this PC has crummy , CCFL back lamp tubes that when dead screen goes, dead, as most have this old.
only few never used laptops last 10 years old.
so with the flash light (dark room) at an angle shin the LCD
see data, now on the screen, yes, that is a DEAD CCLF.
on ebay you see them selling new CCLF screens for this PC.
my bet the CCFL are dead. as most are this old.
All laps this old fail in this order,
BIG battery goes bad or shorts.
COIN cell dead.
CCLF dead ( ended about year 2010 , LED back lamps began)
HDD dead at 5 to 10 years old.
this is all Expected. all from carbon14 dating a PC, I can say that.
yours is 2008 made.
Aug 17, 2018 | Acer Computers & Internet
Gradually lost picture; Mitsubishi VS-50501A
you need to buy a new lamp and replace the old one thats your only problem its about $200 for the lamp
Mar 27, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Mar 14, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi projection Model # VS-50501A (Power cutout)
they are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
Aug 19, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Power interrup
Good Day, qfd333;
To find suspected liquid the PCB's, remove the front speaker cover and the small board held on by 5-6 screws. Look at the first 3 to 5" on the PCB. Use bright light it's not always easy to see. If fluid is spotted remove the boards from the back of TV. Use small brush, like old tooth brush, and acetone. You can get acetone from hardware stores
Look for rusted wires or parts and replace as necessary.
Good Luck, big IRISH.
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
Green lines at top
well i think your husband is right. it might be three years old, but the sligtest damage can kill it. so what you need to do is start saving up for a new tv. sorry for waht happened. maybe somebody hit the screen?
Sep 01, 2007 | RCA 27R410T 27" TV
Televison & Video Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
