Question about GE Microwave Ovens
GE T20 Advantium microwave convection oven about 2 years old. The door latch is releasing much harder and the door is about 1/8 inch lower at the end opposite the hinge. What can I do to fix?
SOURCE: Advantium 120 Microwave / Convection Over
http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Posted on Oct 08, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Broken Bottom Latch Pawl GE Advantium 120 Microwave
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
highspeedsan
  • 61 Answers
SOURCE: The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Posted on Apr 27, 2009
  • 1335 Answers
SOURCE: Door will not open. Button release does not release the door latches.
The plastic lever release is more than likely broken. You can order the part from
http://www.repairclinic.com/Appliance-Parts?s=t-KCMS145JSS0-%3d%3dc226g5
It's about twenty dollars.
Posted on May 22, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: Kenmore Elite Advantium 120, model # 363.63693301,
You probably just have a bad primary interlock (upper door switch) or its mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
For more on door switches & mounts, see:
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
But if you need any cosmetic parts,
enter your full model number at the Sears parts site.
Posted on Jul 13, 2009
Advantium 120 interior light won't go out
door switch is bad or out of adjustment I have a dometic that does this sometimes I just slam it a little harder
Jan 29, 2014 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
Broken bottom latch on GE Advantium 120
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Dec 24, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 Keeps running
I've got this problem also.
The interior light on the oven died. We replaced it. Since replacing it the light stays on and the turn table turns.
Looking at the diagram, the "main relay" is what powers both. My guess is that it's stuck in the "on" position. Solution will be replace the relay.
Long term fix may be bigger relay.
Jan 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Power Out
Common problem with the Advantium. Culprit is a thermal cut off (TCO) for the cavity. Other posts detail where it is. I ordered a replacement at the link below.
http://www.mouser.com/search/ProductDetail.aspx?qs=i1kXDmddXkNuE3oXZkbuYw%3d%3d
Jan 16, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 door latch repair
Does the model you have have the vent that comes out at you. If so you need to take the screws out of the top front. Then after they are out not to hard slide the vent to the left give a little force. the vent comes off then you can access the screw that holds in the board
Jul 03, 2007 | GE Advantium 120 Convection/Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
