Question about Miele W310 Front Load Washer
There is a really bad smell in my washing machine. i think it might be the rubber seal.
  • silver top May 11, 2010
    hi if this smell ? is like sewerage ? then you may have an item of clothing between inner and outer drum could be sock or just collection of ? as you do not say sink drain smells ?the dependant on where the pump drain pipe is fitted to? i would remove rear panel to access the drain hose from drum to discharge pump and remove it to check inside ?
We have had similar problem with a W828 and tracked it down to an accumulation of water and gunge in the folds of the rubber sheath between the inner and outer drums.  If you open the door and wipe out moisture in the fold that may help.
Posted on Jun 17, 2009
  • 297 Answers
If burned rubber or insulation you can tell. Burning smell
Just bad odour can be from clogged filter, clean it periodically.
When not regularly cleaned and use on 30 -40 degree celsius, fungus becomes a problem. You can try cleaning the soap box and compartment with ttootbrush (old). And run the machine hot empty. When over the years fungus got everywhere, you need to disaassemble all or buy a new one. Don't try aggresive cleaners.
Also you might have a problem to the waterlock to your sewer. Check hose.
Posted on Apr 16, 2009
Kenmore front load washer model number 417. It's been smelling after use.
The rubber seal /boot can be replaced If it's really bad but you will need to clean soap dispenser pull it out all the way buy washer magic to clean rubber seal and door also buy afresh put two tables in tub run longest and hottest cycle with extra rinse once cycle finishes than take half bottle of washer magic and pour into soap dispenser run another cycle if still bad do it all again
Apr 23, 2016 | Kenmore Washing Machines
My Kenmore enery star leaks from the door and now it won't spin and it smells like rubber melting it was my worst purchase ever.
Some machines are a real pain .I agree. But please look for the origin of the smell. It can be due to belt wearing, fault inthe gasket, the motor faulting.
You inspection is important than to think of all the parts that can smell rubber.
Please also check the gasket for poor sealing, if so remove, clean and set or if really bad replace.
Aug 27, 2010 | Kenmore Energy Star 44092 Front Load...
I have an LG washer that smells like rotten clothes. My clothes come out smelling real bad. I checked inside and noticed that the rubber seal around the door is holding moldy rotton gunk. It's not self...
Run a cup each of baking soda and vineger thru a hot wash. Might have to do this a couple of time if smell really bad.
Take out the unit where the liquid soap, softner, etc goes and clean by hand.
Soak a cloth in vinegar and clean the inside of the rubber around the tub.
And finally DO NOT LEAVE THE DOOR CLOSED IF NOT IN USE.
Oct 31, 2009 | LG WM2688HWM TROMM SteamWasher
Slimy mold in rubber seal
Hi, Just dry the seal after a wash and leave the door open just a little. Leaving the door cracked will also help with the smell allowing air to circulate through the machine. ALL front loads have this problem with mold and that strange smell.
Sep 05, 2009 | Washing Machines
It makes my clothes smell really bad
I am not familar with this machine...but
it probably has a lint filter on the washer somewher inside the tub. Probably close to the front. also these front loaders have a big rubber seal, check and make sure nothing has fallen in between them. They make a specific product for cleaning these machines, sell it on same isle as detergent.
Jul 19, 2009 | Samsung WF337AA Front Load Washer
Dirty sock smell
My suggestion is to contact Maytag. I have the same problem. Maytag can tell you what you can do to reduce the odor. I think the problem originates from the fact that the drum always has water in it and the rubber seal has a bad smell.
Sep 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bed Smell
this sounds like you need the rubber replacing around the drum that seals the door to stop it leakig when the washing machine is in teh spin cycle this gets hot and starts to smell this can get really bad and will eventually start to leak this can be replaced but you will need to get someone to do it for you as it is a big job shouldnt cost to much to get done but will be cheaper than replacing the whole machine hope this is some help................
Oct 30, 2007 | LG WM1814CW Front Load Washer
Bosch Axxis Front Load Washer
This video will show you how to change a door seal on this Bosch GLTF2940ES front loader washing machine
You can get seals on eBay
Aug 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Miele W310 Front Load Washer Logo
601 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
