Question about Sharp EL-2630P Calculator
Printing The printer paper accidentally rolled back into the feed area. In trying to dislodge the paper, I accidentally turned the wheel (paper feed roller) and now there is an error on the print function. The claculator function works but the paper feed is out of commission. Is there a fix or does it need factory repair?
  • 682 Answers
It needs fine adjustment to printer by service center.
Posted on Mar 18, 2008
SOURCE:
Lexmark printer wont print
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Jan 04, 2012 | Lexmark X4650 All-In-One InkJet Printer
Printer is making a clicking sound when trying to print and paper won't feed all the way through. This is the first time this has occured. I have turn the printer off, turned off the computer and...
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 24, 2011 | Lexmark X73 All-In-One InkJet Printer
Printer does not feed paper
There could be something blocking the paper path like debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
Sep 22, 2011 | Lexmark X5470 All-In-One InkJet Printer
My printer X3350 has trouble grabbing the paper from the paper tray. What can is the problem. I tried cleaning the grabber wheel. But it still won't grab the paper.
Sep 21, 2011 | Lexmark X3350 All-In-One InkJet Printer
Lexmark 4650 paper wont feed when printing. It starts the feed process but does not catch the paper. when it does it will take several sheets.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 20, 2011 | Lexmark X4650 InkJet Printer
My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
Sep 03, 2011 | Lexmark X2600 InkJet Printer
The printer was printing OK. Suddenly the paper refeed into the printer. I removed the paper but now the printer is not feeding paper. I think I may have move or disloged a sensor in the paper feeder...
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 30, 2011 | Lexmark X4650 InkJet Printer
I can't get the paper feed to work properly. Printer is telling me to load paper when it is full of paper Printer is asking me to clear paper jam when there is no paper jam Printer is just not...
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
My pinter is an X4270. It prints well, but will not feed the paper to fax, scan or copy. I keep getting a clear paper jam reading, but there is no paper jam.
Aug 07, 2011 | Lexmark X4270 All-In-One InkJet Printer
When printing the paper is not drawn down straight - pulls to one side - and then becomes jammed. This has happened over and over. Is there a wheel or something of track - can I fix this myself. Thanks...
There could be something that's blocking the paper feed system. Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area.
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
You may also refer to this article in the Lexmark website: How to Remove and/or Avoid a Paper Jam in your Lexmark X5300 & X5400 & X5600 Series All-In-One
May 10, 2011 | Lexmark X5495 Printer
Sharp EL-2630P Calculator Logo
655 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
