Question about Western Digital Caviar SE16 (WD5000KS) (5000KS20PK) 500 GB Hard Drive
Bad logic board on Western Digital Caviar SE16 500 GB SATA Hard drive
My WD 500GB SATA WD5000KS went out on me, stopped spinning. I need the data (no backups) and I don't want to spend 3k-4k for data recovery, if I don't have to. I tried finding an identical replacement drive to attempt a logic board swap, but only found 1 that is close, but not matching the DCM#. Apparently I need a WD5000KS-00MNB0 model with a DCM# close to HBHCAJAAB or the board swap wont work. The 1 I found does enable the drive to spin up, but BIOS now says hard drive error, and I can't access anything on it.(tried software data recovery to no avail) The board I found on eBay has a DCM# of HCHCAJAAB and was same date of manufacture, and not it spins and clicks, whereas before I swapped the logic boards it did not spin at all. If anyone has a suggestion for this problem I would very grateful, Ed Spann
  • timmitim May 13, 2008
    I have seen that you talked in the last year about a WD5000YS with the DCM "HCHCAJAAB".
    Does anybody has a glue where to find this HD?
    I would need it very urgent and would be glad for any information where I could get such a HD with the exact DCM.
    Thanks
    Please email me.
  • willsilk16 Jan 05, 2009
    My hard drive was an external Maxtor 500gb, it would show as connected by usb but nothing in my computer, eventually i took it apart to find that its a normal SATA Maxtor 500gb and that there is a chip thats freid on my logic board.
    now i need to find the exact same logic board to replace it. can you help?
    New Friend:
  • 4 Answers
Might i suggest you try http://www.onepcbsolution.com/ to get an exact replacement board.
Posted on Nov 06, 2012
I just had the same problem today. I found this place.
http://www.lowcostrecovery.com/pricing.html
Posted on Dec 24, 2007
I Have a 1tb with the same problem i can't get to match the dcm.
Does anyone know where i can get a 1TB with DCM#HBRCHV2AB?
I will buy it from anyone who has one
Posted on Apr 17, 2009
SOURCE:
WD15EARS will not power up, will adding a new logic board fix it?
You may want to contact WD' website. I don't know of anywhere you can get just the logic board.
Feb 18, 2013 | Western Digital WD Caviar Green WD5000AADS...
What jumpers are for slave Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
SATA drives don't need jumpers. Just install the drive and the computer will assign a drive letter.
Jun 06, 2012 | Western Digital WD Caviar Blue WD3200AAJS...
My computer is not recognizing my western digital caviar Se16 500GB
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 27, 2011 | Western Digital Caviar SE16 (WD5000KS)...
My HD caviar wd 500GB starts it's functon test then switches off. The front light comes on for about half a second, then all stops.
does he makes any sound (ticking)... while running?
dos it appear in the cmos setup under the first option?
May 12, 2010 | Western Digital Caviar SE16 (WD5000KS)...
WD 500g hard drive computer cant read it
i suspect ,if there was no bad sounds on the drive when it was wrking ,that it must be the circut board on back of drive . i ,m in the same boat myself & i,m trying to track down same type of c/board.i do not think this is mechanical bit, electrictal
soretoe
Jul 17, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
WD5000aaks western digital 500GB HDD motor not spining,
Try reseating the power connector for the drive. You can try another unused connector if it will reach. Do the same for the data cable. Reseat both ends of the cable a couple of times to shine up the contacts. If none of this works, then a data recovery service will be needed.
Jul 14, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
Western Digital 500GB SATA
Hi, you dont say whether you have it installed in the pc, or is it in an external usb enclosure? Come back to me and I will try for you.
Apr 02, 2008 | Western Digital Caviar SE16 (WD5000KS)...
Bad logic board on Western Digital Caviar SE16 500...
Are you still looking for the PCB?
Maybe I can help you to find it.
PM me on this forum http://forum.hddguru.com/hard-disk-drives-repair-and-data-recovery-f1/
Username: dav34
Oct 01, 2007 | Western Digital Caviar SE16 (WD5000KS)...
Open Questions:
Dell Printer tech support +1=855=536=5666+ Dell Printer Toll free Number MCTJMNO Dell Printer assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Dell Printer helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. Dell Printer TeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... Dell Printer Tech Support Phone Number +{1-855*536*5666*} to resolve all Dell Printer products. is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .Dell Printer CUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL Dell Printer CUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. Dell Printer CUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Dell Printer tech support pHoNe {18555365-666-}} nUmBeR USA Dell Printer tech support pHoNe Number {18555365-666-} to resolve all Dell Printer products. Dell Printer is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. Dell Printers Support Phone Number for Dell Printer Technical support help. Dell Printer Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 16, 2019 | Dell Computers & Internet
Malwarebytes Telephone nUMber $1 855 536 5666 $ Dz`& ]NT Malwarebytes Telephone $O1.855.5365.666$ nUMber tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Oct 16, 2019 | Carrier Computers & Internet
See all Western Digital Caviar SE16 (WD5000KS) Questions
Western Digital Caviar SE16 (WD5000KS) (5000KS20PK) 500 GB Hard Drive Logo
2,311 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
