Question about Canon PIXMA MP620 All-In-One InkJet Printer
Can't find ink storage
Can't figure out how to replace ink cartridge on PIXMA MP620
    President:
  • 414 Answers
Look at this
Details Issue: How do I replace or insert an ink tank?
Solution: Install the Print Head and Ink Tanks - MP620 / MP620B
  1. Open the Paper Output Tray (A), then lift the Scanning Unit (Cover) (B) until it locks into place.
    The Scanning Unit (Cover) (B) is fixed automatically.
    The Print Head Holder (C) comes out. (This is where you install the Print Head.)
    Note : Close the Document Cover (D) and lift it with the Scanning Unit (Cover).
  2. Raise the Print Head Lock Lever (E).
    i_expl.gifCaution : Firmly raise the Print Head Lock Lever until it stops. (The Print Head Lock Lever may feel heavy.)can't find ink storage - i_note_e.gifi_note_e.gif Note : If the Print Head Holder does not move, make sure that the machine is turned on.
  3. Remove the Print Head from tcan't find ink storage - i_expl.gifpackage.
    i_expl.gifCaution : There may be some transparent or light blue ink on the inside of the bag the Print Head comes in, or the inside of the protective cap - this has no effect on print quality. Be careful not to get ink on yourself when handling these items. Be careful not to stain your hands.
  5. Tilt the Print Head and scan't find ink storage - lockphinplace.gifower the Print Head Lock Lever (E) completely.
    i_expl.gifCaution : Do not knock the Print Head against the sides of the Holder.
    Be sure to install it in a well-lit environment.
    Pinch the Print Head Lock Lever firmly and lower it gently.
    Once you have installed the Print Head, do not remove it unnecessarily.
Install the Ink Tanks
  1. Pull the orcan't find ink storage - peeltank.gifb>1) in the direction of the arrow to peel off the protective film and remove the film (2) completely.
    While pressing down with your left thumb, twist off the orange protecan't find ink storage - i_expl.gif(A) located on the bottom of the ink tank.
    i_expl.gifCaution : Do not hold the sides of the ink tank; ink may splash.
  2. Install the Ink Tank
    Press the PUSH mark on the ink tank uncan't find ink storage - i_important.gifnto place.
    Make sure the Ink lamp lights red.
    i_expl.gifCaution :Be sure to install it in a welcan't find ink storage - snaptherestin.gif
    i_important.gif Match the labels when installing.
  3. Install all the other ink tanks in the same way.
    Install all the ink tanks.
    i_expl.gifCcan't find ink storage - shutthelid.gifspan>Once you have installed the ink tanks, do not remove them unnecessarily.
    i_important_e.gif Important :can't find ink storage - backtotop_button.gifnk lamp lights red.
  4. Close the Scanning Unit (Cover) (B).
Mark
Posted on Apr 16, 2009
The following ink tank can not be recognized on mp620?
i would not refill my own cartridge tank with 3rd party if i were you. stick to OEM print carts only . Canon is very pickey when it comes to using OEM cartridges. call Canon direct to get new OEM cartridges 1-866-226-6634
Jan 03, 2012 | Canon PIXMA MP620 All-In-One InkJet...
Where is the serialnumber of the Pixma MP620 printer?
with the front panel down, lift the top cover and the glass scan screen panel, this will reveal the ink cartridges, wait until the cartridges have moved left then look down to the right of the cartridges, on the silver chassis you will see the serial number.
Feb 21, 2011 | Canon PIXMA MP620 All-In-One InkJet...
My canon pixma mp620 won't print black ink but other colors print ok.
Does printer have 2 black cartridges, 1 large 1 small? if so, the small black one and colors only takes care of the color print jobs and the large black one, the main black and white jobs. Make sure you don't have an empty large black cartridge.
Aug 15, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Blurry photos from Canon PIXMA MP620
Either ink cartridges or PRINT HEAD faulty
May 25, 2010 | Canon PIXMA MP620 All-In-One InkJet...
U130 ink message on pixma mp620
Very simple solution: When the pixma mp620 screen shows error U130, Hold down the stop (red triangle) key for about 7 - 10 seconds. This overrides/turns off the ink monitoring function. The printer will begin "thinking" for a bit and then start printing. Note: you may have to do this seperately for each color. You'll also notice that when the lid is open and the cartridges are in position for changing, the cartridges that used to be "out" are no longer flashing red, nor a stead red. They are dark.
Feb 17, 2010 | Canon PIXMA MP620 All-In-One InkJet...
What is the purpose of the small black in cartridge
They are both described as black but the larger one is "pigment" black. So the answer is they will not switch over because they are different inks and different sizes.
Jan 10, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Low ink disables scanner
you can replace the cartridge if you want,but if you want to disable the ink level monitoring,you have to follow the on screen instruction from canon that will pop up on your screen,until you get the message "press stop/reset button for 5 seconds".
Sep 10, 2009 | Canon PIXMA MP620 All-In-One InkJet...
I want to chgange the black ink cartridge
Go to:
Canon MP620 Support
Select the "Support & Service" tab if it is not already showing.
Type insert ink tank in the space to "Please enter your question" block.
"How do I replace or insert an ink tank?" should be the first result showing.
Click on that link and it will open up detailed instructions with pictures on replaing the ink.
Thanks for using Fixya.
May 08, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Canon PIXMA MP620 All-In-One InkJet Printer Logo
418 people viewed this question
old marine
old marine
