Question about HP ZT3380US (PF083UA#ABA) PC Notebook
HP ZT3380US drops Network
This has been a good computer. Recently began dropping the network connection....both wired and wireless LAN. It connects for 20 seconds, and then disconnects automatically for 3-5 while it reloates itself in time/space, then goes thru the cycle again. I have attempted to update the drivers specific to the onboard Ethernet and wireless network interfaces, and the 1394 adapter also. Nothing has worked. short of taking it all the way back to a clean disk and fresh OS install, I am at wits end. all thoughts appreciate, thanks in advance, Gino
Limited acess with wifi bluetooth error with Asus K55VD-SX405
If windows7 open network and sharing center then manage wireless networks then remove all networks there then click on change adapter settings right click your wireless LAN \proprieties\TCP/IP V4 use automatic IP and dns \ok\ok then disable enable it then try to connect.......Good Luck
Feb 03, 2013 | Computers & Internet
HP Elitebook and Apple Extreme wireless connection isssue.
You may want to see if you are able to change the preamble on computer and the router to use short preamble. If you are using Windows you can go to the network connections to check the advance properties of your wireless card. As for the Apple Airport Extreme you will have to contact Apple for information if your router can change the preamble.
Jan 29, 2013 | Computers & Internet
Dose the hp omnibook xe4100 have wirless or do i need a wireless card
You could do with the instruction manual, download from here:-
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/lpi06480/lpi06480.pdf
On page 14, it shows where the wireless on-off button would/should be
on page 67 it states:-
If your computer includes a wireless on-off button-located on the right side of the front
of the computer-you can connect by radio to a wireless local area network (LAN) and
access computers and other resources on the network.
A wireless network provides all the functions of a typical "wired" network, but also
provides for "roaming." Since your computer connects to the network by radio rather
than through cables, you can move from place to place within the network-from your
office to a conference room, for example-and remain on the network the entire time.
Dec 31, 2010 | HP OmniBook XE4100 Notebook
Internet/network problems
Connecting the laptop to your network using a network cable, does this solve your Internet problems?
Does this works without the Internet connection dropping out?
If the wireless connection has a low signal, try positioning the wireless router or the laptop to get a better signal strength.
Also try reinstalling your wireless driver.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Will a computer with 10/10 LAN connect to my wireless LAN?
The 10/100 LAN is a wired connection. If it is connected to the wrt54g through an ethernet cable yes it will see anything on the wireless connection but if you want the computer to use a wireless connection then you will need to get an 802.11B or 802.11G wireless adapter. The wireless adapter does not have to be Linksys but it does generally make thing easier if you use all the same brand.
Nov 29, 2008 | HP AdvanceStack 10:10 LAN Bridge MB...
Internet Intermittent Drop Out
To isolate the problem beter connect your wireless router directly to the modem and configure it, check if you are able to go online properly so that you can figure out the problem if your wireless router is not working properly, try upgrading the latest firmware and reset the router and reconfigure the router and that will fix your problem...
Oct 22, 2008 | Linksys Wireless-G WRT54G Router
My network wireless adapter keeps dropping off
I would check with HP and see if they have a Vista driver for the wireless card. It sames to be the driver is in consistant.
Jan 03, 2008 | Computers & Internet
2Wire USB 802.11g adaptor on XP: drops wireless periodically
when you get your computer connected, set the wireless channel to 6 and disable wireless zero configuration that will stablize your connection
Dec 03, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
HP ZT3380US (PF083UA#ABA) PC Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
