Question about Kidde Nighthawk Combo Gas/co Detector
Gas alarm 220
Went off gas 221 reset put in new battery same problem gas 221
    Sniper:
  • 54 Answers
All gas detectors have an internal sensor that can be "poisoned" if you are not careful. They are especially sensitive to cleaning products that contain amonnia or aerosal spray cans. If these products are used in close proximity to the detector there is a good chance of permanently damaging the unit. The only recourse you have is to buy a new unit.
Posted on Aug 13, 2009
If driven with alarm sounding when battery replaced in key will it run funny
It surely can and will. Most likely all you need to do is have the codes erased.
Jul 24, 2015 | 2007 Toyota RAV4
I have a 97 tahoe with crime stopper sp101 alarm. truck was working fine until i put a new battery in, now gas gage is going haywire,and no signal to fuel pump. any solutions, or suggestions. i know its...
when u disconnected the battery you activated the alarm system which has a fuel shut off you need to reset the alarm system ,,check the system for a malfunction [could have received a power surge when battery was hooked up] or remove the alarm system
Aug 13, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
I own a Canon PIXMA MX860 printer. I have several extra CLI-221 Black ink carriages, but my PGI-220 Black shows it needs to be replaced. Is there a way I can use up some of my extra CLI-221 Black...
Hello, if your printer tells you need to replace the cartridges just press stop/cancel buton for at least 5 second and then you can use the printer only on black. I dont recomend you do that becouse your printhead might burnout.
Jan 05, 2012 | Canon Office Equipment & Supplies
My Kidde Nighthawk Carbon Monoxide detector was beeping shrilly and read gas. When pressed the reset button it read 221. Problem was it was sitting facedown in a box (i'd just taken it from my old...
A reading of 221 ppm carbon monoxide gas is a dangerous level that should be taken seriously. You could try a new battery and reset the detector. If in doubt, always err on the cautious side and have the apartment checked by a professional or by the local fire department.
A new carbon monoxide detector is a small investment that may prevent carbon monoxide poisoning or death.
Jul 22, 2010 | Kidde Nighthawk Combo Gas/co Detector
Will not start
Hi yes there is a fuel reset in the footwell below the steering wheel ,
my guess though is the car is immobilised by the security system registering a battery tamper . Use the key to enter the car put the key in position 2 ,
Regards
Fin
May 10, 2010 | 2001 Jaguar XJ8
Turn off alarm for sportline 220/221 stop watch
Press the mode button twice to enter the alarm setting mode, the press the other two button simultaneously to turn OFF the alarm.
The same actions will turn the alarm ON.
Jan 27, 2010 | Watches
Car sat for six months. Battery went dead and replaced with new one. Got it started after new battery, now it won't start, the alarm led is either flashing bright or very dim flashing fast. I'm sure that...
When alarm goes off,put key in ignition and turn,the alarm should go off and alarm should be reset.Or,remove positive battery cable,wait 10 minutes,reconnect,when you open door,alarm will sound,insert key in ignition and turn key and alarm should go off and alarm should be reset.
Aug 14, 2017 | 1994 Toyota 4Runner
Changed the battery. The alarm went off, tried to reset but will not work. When driving push on the brakes and the car shut down. Is this an alarm issue or an electrical engine issue. Don't know what to...
Yes this is an Alarm issue that's why your vehicle is shutting down as soon as you press on the brake pedal. Is this an aftermarket alarm or stock alarm? Sounds like aftermarket alarm to me and if it is, the way fix this issue is as soon as you put the red n black terminal on the battery and the alarm goes off press your alarm key right away to turn it off. If this doesn't work put your key on the ignition after you have installed the battery and just put it on the "ON" position engine OFF then click on your alarm remote once again.
Sep 23, 2008 | Mitsubishi Eclipse Cars & Trucks
Kidde Nighthawk Combo Gas/co Detector Logo
1,088 people viewed this question
Top Kidde Home Security Experts
richie46
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
