Question about Logitech X-530 Computer Speakers
R Front Speaker Doesn't Work
All the wiring from the speaker works fine it seems, it still sends the power signal to the sub and the other four speakers are playing the music. There's just no sound coming out of that one speaker and I can't begin to think of why.
  • brewhomiec Nov 11, 2007
    No sound coming out of RF speaker. I've tested the speakers with the 3.5mm jack test suggested and they all work fine. When I run a channel test with the 'Creative Speaker Settings Program' I can hear the voice saying "Front Left" - "Front Centre" - then an extremely muffled FR (which seems to be coming from the sub?! - "Rear Right" - "Rear Left".
    Scholar:
  • 57 Answers
Dude Here is a link that gives you a step by step testing procedure. Sounds like a defect in that particular speaker, you will know with this test from logitech. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=2913&p_created=1125714076
Posted on Sep 19, 2007
I conected my sub wrong and the unit shut down , I reconected my sub and everything seems to work fine , should I send it in for servicing?
If i'm right, the system powers down as a safety precaution. It prevented itself that it will breakdown. It's your choice but I recon you can just enjoy and listen to your favourite music.
Apr 26, 2014 | Harman Kardon AVR 7000
Not sure what the wires colours are
We dont either. You need to post what you are trying to connect. Amplifier? Sub? Speakers? Head Unit im sure. But you need to look for the radios wiring diagram.. Today's radios are generally basic with the color scheme. Black is ground. Red is switched power. Yellow is constant power. Orange if for dash illumination... Speakers are usually 4 colors. 2 wires a speaker. For instance Front Left would be White/Black-Stripe. White being the positive and black strip being the negative. Usually the four main colors for the speakers are White......Gray.......Purple..... Green... with the striped wires going to the negative on each speaker. Blue wires are usually for power antennaes or also used to send trigger signal to the amps to turn on and off.
Jul 11, 2011 | Car Audio & Video
Sub box is not working ,amp has power no idea what to check next, ground wire is secure and is good
You should double check your connection to the sub. Make sure that no speaker wires are touching each other. Sometimes you won't get anything to work if pieces of the frayed bare wire on the positive cable are touching parts of the negative.
Is this a dual or single voice coil speaker? or to re-phrase it, does it have one or two speaker terminals?
I would also check your line in to the amp. Make sure it is sending a signal to the amp. If available connect the audio signal to some other component like a boombox or AV Receiver that has a proper connection.
Mar 08, 2011 | Cadence ZXW122 Car Speaker
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Power not working
If it is fused check to see if the fuse is blown... Start with power and work you way down from there.
Power to the sub.
Signal to the sub
Cabling to sub
Check the speaker itself to see if it is good.
john
Aug 16, 2008 | JBL PSW-D112 Speaker
Sony cdex-m630 connections with an amp
You can use either set of RCA outputs for the amplifier that you want to. Only difference in either of them is front, rear and sub outputs. If you are only powering a sub amp, then use the sub outputs, otherwise, the other two will work fine. You can still use the outputs from the radio itself to power four other speakers while using the RCA outputs.
Jun 26, 2008 | Sony CDX-M630 CD Player
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
Subwoofer
I suppose that your system requires an active subwoofer, and that you provide one. Some systems, if SPEAKER SIZE in SETUP are set to LARGE for front or center speakers, do not send signal to sub, system redirect signal to front or center speaker. Try to check this.
Oct 05, 2007 | Pioneer HTP-2900 System
Power Indicator Light on Front Doesn't Light
The indicator light needs to be replaced, there is a loose or poorly soldered connection on one of the led's leads, or the circuit providing the signal (voltage) for the light isn't functioning.
Sep 17, 2007 | Paradigm PDR 10 Speaker
Logitech X-530 Computer Speakers Logo
102 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
