Question about Air Tools & Compressors
Engine will not start. Trying pull out an injector to check spray volume. Can't seem to get it loose to pull out. Is there some ''trick' to releasing the injector?
  • 3 more comments
  • rlcampolongo Apr 20, 2009
    Not sure what you mean by "pop test". We have an injector tester that will feed fuel via a hand pump to check the spray pressure and pattern.
    When I turn to loosen the injector, I hear a click noise with a 1/16th turn, but I am not able to pull it out of the head.
  • camp103 May 11, 2010
    Thanks I'll give it a try tomorrow.
  • mdm972 May 11, 2010
    Are you performing a "pop test" on that injector?
    The injector is in a Deutz 3 cylinder diesel. Large "jackhammer' type of compressor.
  • JODY BRIDGERS May 11, 2010
    IS THIS A DIESEL JACKHAMMER COMPRESSOR OR A SMALL PORTABLE GAS? INJECTOR?
    Scholar:
  • 89 Answers
IS YOUR TOGGLE SWITCH TO CUT IT ON AND OFF WORKING PROPERLY, ALL YOUR SHUTOFF SENSORS ( LOW OIL,ETC) BYPASSING CORRECTLY DURING STARTUP BY THE BYPASS BUTTON BEING DEPRESSED.
YOU CAN ALSO TRY SOAKING A RAG WITH GASOLINE AND RINGING IT OUT GOOD. NOW HOLD IT OVER THE "MOTOR" INTAKE-HOLD GOOD AND DONT LET GO- AND SEE IF IT WILL START. IT ACTS LIKE ETHER BUT WONT VAPOR LOCK IT. THIS WILL ALSO HELP GET RID OF AIR IN YOUR INJECTION SYSTEM.
Posted on Apr 21, 2009
I replaced the motor in a 96 isuzu homebre. All the wires are hooked up. The engine will crank but wont start unless either is sprayed into the throttle body. Seems like the injectors aren't working.
first off check that your fuel pump is sending fuel to injection system. Usually there a release valve on the fuel rail somewhere. check it for fuel pressure.
Feb 18, 2014 | 1996 Isuzu Hombre
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
1992 isuzu pickup,2.6 engine , surges up and down after 10 minutes then shuts off
1992, PICKUP, in USA? what country , ? cars are not same all over earth. sorry.
engine surges, then stalls. correct.>?
nice testing , rare here, real nice !!!!
spark good as it stalls
so if engine is ok, compression, (seems cat is not melted with 20 " HG)
is flooding or starving for fuel,.
one or the other, you can find that out.
if spark timing was ok, then the belt did not slip. on cam)
leaving only fuel issues.
so DO the magic , WOT, cranking trick this trick (logic in ECU)
cuts the injectors dead, cranked, to unflood all engine with EFI.
do that?
check spark tips, for 3 to 4 hours dead.? be next
2.6L (is 4 cylinder.) is cam belt drive, i never fail to check it first
the fail, at 60k miles, all do. all rubber band engines do.,
if all this is ok, not flooding
one can start engine with test fuel, and even keep it running
even with (hint) fuel pump relay pulled.
if that works, the fueling is wrong.
injectors leaking,? ?
if only one spark tip is wet , soaking in fuel, Injector issues.
when it stalled pull all 4 plugs and look at the tips.
(if cam is timed right) be super super first thing, on this 4 banger.
Mar 08, 2017 | 1992 Isuzu Pickup
97ford explore is not getting gas after changing fuel pump
Be sure your fuel filter isnt clogged also check the fueses if both of these are ok check the crank sensor it sends information to the pcm telling it you are trying to start the engine it then sends a signal to the injectors to spray fuel but if the crank sensor is bad then the pcm doesnt know you are trying to start the engine and therefore never sends the signal to the injectors to spray fuel.
Jan 30, 2011 | Ford Explorer Cars & Trucks
My 1995 Pontiac Bonneville will turn over and start but always dies. Already replaced fuel filter and the fuel pump seems to be working but the car will not stay started. Checked the gas release on fuel...
crank position sensor...if the engine will start and run for a second or two then it dies. If, however, you can press and hold the gas pedal slightly and keep the engine going, then I would suspect the IAC-idle air control valve. This can be cleaned with spray carb cleaner.
Oct 12, 2010 | 1995 Pontiac Bonneville
1990 toyota pickup engine won't start
CHECK THE COLD START INJECTOR ON THE INTAKE MANIFIOLD.
1. UNPLUG THE POWER WIRES TO THE IGNITION COIL(NOT THE HI VOLTAGE WIRE TO THE DISTRIBUTOR)
2, UN BOLT AND PULL OUT THE COLD START INJECTOR(LEAVE IT PLUGED IN TO POWER AND FUEL
3. BREIFLY CRANK OVER THE ENGINE AND WATCH THE SPRAY FROM THE TIP. (A FIRE EXTINGUSHER WOULD BE A VERY GOOD IDEA)
4. HOW DID THE SPRAY LOOK
WAS THE SPRAY QUICK, IN A FINE MIST? IF SO ITS OK AND NOT THE PROBLEM.
IF IF IT RAN ON, A STEADY STREAM OR POURED OUT THERE IS SOME THING WRONGE WITH THE COLD START INJECTOR
Oct 28, 2009 | 1990 Toyota Pickup
1995 buick lesabre custom. has a new fuel
even if you have preasure in the line that does not mean you have fuel going into the engine. you should check the injectors to see if they are spraying and if not you need to check the injector pulse to find out if the PCM is sending the signal to them to spray. to check injector pulse you will need a noide light to test the pulse it the light lights up you have pulse, but easy way to check is pull an injector and turn the engine over see if it sprays.
Aug 24, 2009 | 1995 Buick LeSabre
1996 Dodge Intrepid with a 3.3L engine that won't run!!!
great you got it running... who would have dreamed someone would have filled the car with the wrong gas. E85 has alcohol in it. it will dry out and decay certain plastic and rubber type parts in the fuel system if the car was not made for this type fuel.
Jun 11, 2009 | 1996 Dodge Intrepid
99 ford taurus will not start
buy a can of carburator cleaner, spray into duct area while cranking engine. Does engine try to start(fire)? If so, find inertia switch (button in trunk). 'reset button just by pushing it. If this switch was triped, fuel injectors or fuel pump will not operaate. If spraying carb cleaner does not help starting then fuel pressure should be checked to rule out fuel delevery problem. AS a precaution, make sure your useing the correct key(original). Security problems also shut off fuel.
Nov 21, 2008 | 1999 Ford Taurus
Air Tools & Compressors Logo
90 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
