Question about Bose Lifestyle 28 System
Error message: custom eq error:10
Zone 2 speakers where working 100%.Then when tried playing them recently and there was no sound , then they started to play but i could not adjust sound via remote, then thy would go off again when i fiddled with remote. Now my first remote for zone 1 also giving trouble, i switch on unit with remote, but seems to be working another zone and when i physically switch power on unit then the original zone 1 comes on, i dont know whats going on, i then inserted the iq disc maybe it would sort it out but is shows and error message, something about custom eq setting error:10 call bose. Please help.thanks
  • 2 more comments
  • charly36 Nov 24, 2007
    I have the same problem as you have custom EQ error 10 call bose ,what can be the problem?
  • Anonymous Dec 16, 2007
    error 10 on bose lifestyle 38
  • jmcnick45 Sep 01, 2008
    I have just setup my Lifestyle 28 System. I have been having problems intermittently when switching between components where the surround sound feature will turn off and revert to onlt front speakers working. I subsequently shut off the acoustimas module and turned it back on. Now none of the speakers will work at all and I am getting the following error when running setup CD - "CUSTOM EQ ERROR:10" Call Bose......
  • caunhye Sep 02, 2008
    same problem. what to do?
4 Suggested Answers
SOURCE:
SOURCE: Bose - Custom EQ Error: 10
i had the same problem but it was a stupid mistake, i forgot to flick the power switch on the acoustimass module! In short it means for some reason the accoustimass module is having trouble communicating with the lifestyle centre.
Posted on Sep 12, 2008
  • 74 Answers
SOURCE: error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
Posted on Dec 09, 2009
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Posted on Dec 31, 2009
Just purchased Sony DA5800 ES reciever will my Bose 901 speakers work with this? Need help
Bose 901 speakers are designed to use with the Bose equaliser patched between the pre-amplifier out and power-amplifier in of your receiver. Having said that, Bose did not invent EQ, neither is EQ a mystical process. Not sure which series 901s you are talking about, but I would definitely be experimenting with the built-in EQ supplied with your Sony DA5800 ES. The manual says you have +/- 10 dB of adjustment for treble and bass for each of the surround channels. That is not really adequate in my opinion, not only would I be seeking +/- 15 dB, but I would also like to be able to apply those adjustments at frequencies chosen by me, not just 'treble' and 'bass' To use the Bose EQ, it needs to be patched between a preamp output and power amp input. The Sony DA5800 ES has preamp outputs, so you could use these (Note that the built-in EQ is disabled when using these outputs) In this case you could either feed the signals back into the Sony (post Bose EQ) perhaps using a different 'Zone'. As an alternative option, you could power your 901's with a stand-alone two channel power amplifier. Then you get the full benefit of the Bose EQ as well as the surround sound from your Sony (front L+R speakers off) It all sounds like a lot of fun. Happy listening! Cheers, Don.
Nov 28, 2013 | Bose 901 VI Main / Stereo Speaker
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
We wired our new home to have outdoor speakers and also speakers to our pool room. Before putting the receiver back into place after wiring the back, we quickly touched a speaker's wires to the wires...
It's not really clear if all of this is Zone 2 or not, or if you intend a second program to play in Zone 2.
If your Zone 2 is to a powered amplifier and its speakers the Zone 2 output would be FIXED (not variable from the host TX-SR705), that is, at a level that the receiving amplifier would control.
Page 99 deals with it.
Having just passive speakers in Zone 2 requires you to set Zone 2 to "ACT(ive)".
Mar 27, 2011 | Onkyo TX-SR705 Receiver
I want to hook my bose 901 VI along with EQ to my Luxman R117 Receiver and also run other speakers from the same receiver. Is this possible?
If you are using the Bose Equalizer to optimize the sound of the 901s by going through either a tape loop or a pre-out/main-in loop, then the only way to do this without also equalizing the sound sent to the second set of speakers is to manufacture a "zone-2" output from the Luxman.
You'd probably need to split the send from the Luxman's pre-out before the EQ and send it to a second power amplifier for the second pair of speakers (if you want the Luxman's volume knob to control both speaker sets) or from a tape level output (if you wanted independent volume controls for the two speaker sets.
The whole EQ thing made 901s difficult to use on vintage equipment with only one "zone" audio outputs. Unless you want to use the Bose EQ on the second set, too, you can't do it satisfactorily without adding another stereo amplifier. But, go ahead and try it, you might find that you actually like the odd EQ that the 901s EQ gives to the second pair!
If it were my decision, I probably would not do it without a second amp, but it's all about what you like, my opinions really don't matter in your house, do they?
Have fun
Jul 24, 2010 | Bose 901 VI Main / Stereo Speaker
Outdoor speakers on Zone 2
Hello Fixya customer,
Thank you for your question.
Please verify that Zone II power is "Acitvated" from the Hardware menu.
Thank you for using Fixya, an let me know if you have any additional questions.
May 01, 2010 | Onkyo TX-SR605 Receiver
Trying to hook up 2 Hi Fi speakers to a reciever
Red left to Red left speaker
Black left to Black left speaker
then repeat for right speaker
turn on amp play somthing quite to start, check all is working. To check speakers are in phase play a bit louder and stand exactly in middle, bass should be defined and central, it helps to close eyes and listen. If not central and defined change over Red and Black on one side only then listen again with the same test.
Start flat with eq section adjust as you like when listening to something you know and like.
After all is working ok then make it louder.
Sorted!
Sep 16, 2009 | Audio Players & Recorders
Fender Stage 100 dsp, solid state amp volume (or power) problem
The Deluxe may have more efficient speakers....which would cause it to sound louder. Also, the EQ settings could play a part in this. If the EQ's aren't set the same there could be a noticeable difference in sound.....usually the mids can have quite an effect on overall amp volume....
May 31, 2009 | HHB Radius 50 Tube Amplifier
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
J.
Sep 01, 2008 | Bose Lifestyle 28 System
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Nov 14, 2007 | Yamaha RX-Z9 Receiver
Bose Lifestyle 28 System Logo
871 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
