Question about Mitsubishi WS-65515 65" TV
HDMI connection pin broken/ No signal HDMI
I have a pin broken on HDMI input, can I replace the connector/ or must I R/R the whole card, if so who sells one. It is a simple job to pull the card, the connector looks to be soldered in at two points.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
The HDMI connector is on the HDMI board part# 934C107001 ($92.99 Andrews Electronics)
Posted on Sep 16, 2007
My monitor has no signal
Monitors typically use one or more of the following connectors to your computer:
  1. VGA (15 pin connector) usually Blue
  2. DVI (multiple pin configurations exist) usually white
  3. Display Port
  4. HDMI
Your monitor must be connected with one of these connector cables, and the Input on your monitor needs to be set for the correct input type (usually automatically selects based on detection of which connector the signal is coming through).
Typical things to look for if there is no signal:
  • Cable not fully seated on one or both ends
  • Computer not turned on
  • Bad cable (rare)
  • Bad video card or on-board card in the computer
  • Bad monitor
Dec 28, 2017 | Computers & Internet
Our tv, model 42hp25bat, has been running on our cable input for the past year. All of a sudden the tv input setting says "no signal". The tv works for our DVD player on HDMI setting. We...
the signal input on the cable connection to to your tv (inside your tv) is broken, and possibly needs to be replaced. Possibly few capasitors or other parts might need to be replaced. or the whole signal board.
Apr 17, 2008 | Televison & Video
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
Mar 03, 2015 | ASUS Ve248h 24-inch Led Monitor
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
I put the cable in the cable socket but it still tells me there's no signal. this tv was given to me, so I don't have a manual or a remote.
On your remote, look for the INPUT button.
Push it slowly once at a time. It will change the input your TV is looking for and the cable TV will come up.
Feb 02, 2010 | Haier HLH26ATBB 26 in. LCD Television
I'm trying to use my bravia as a computer monitor.
Your Bravia should have a 15 pin PC input, this input can take most standard PC resolutions, however if you a have a video card with an HDMI port, you should set your resolution to 1920 x 1080 @ 60Hz refresh rate so that the signal can be recognized and processed, many standard PC video resolutions are not compatible with the HDMI inputs. You should not require audio cables unless you are using a DVI to HDMI connection.
Crampy
Dec 11, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hdmi
Hi, =)
Basically what you need is to connect the S/PDIF out from the soundcard\motherboard I/O ports to the 8500 graphics card S/PDIF in and HDMI should now carry both video and audio.
So you have to check the video card. On the top part you'll see a white plastic with 2 pins inside of it. This is the connector SPDIF input from the video card. So what you have to do is look up in your motherboard for a connector with 3 pins that says SPDIF OUT. Even though it looks with 3 pins ONLY 2 of them are needed. You will basically need ONLY a cable like this:
http://www.tigerdirect.com/applications/Se...00&CatId=69
You can get it at a local pc technician shop for 2 bucks only.
Anyway what you do is connect one end of the cable to the two pins from the white connector from the video card and the other end of the cable to your motherboard on the first 2 pins of the SPIDF OUT connector. Now the way to know which ones are the first two, do it this way: The first two considering reading SPIDF OUT meaning that the first one is the one closest to the "S" letter of SPDIF OUT.
If it does not work trying connecting the cable differentely as you might be connecting in a reverse order (positive-negative). Don't worry about burning anything as it's only a sound cable, and it does not carry any power.
Once you do it, go to windows control panel and select SPDIF as your default sound playback.
And you're ready to enjoy sound and video thru HDMI now!
Aug 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Mitsubishi WS-65515 65" TV Logo
441 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
