Question about Electrolux Centralux Vacuum
Brush assembly will no longer spin on carpet however the suction from the system is still good. Unit is only 5 years old.
Have an Electrolux central system, 5 years old, and just recently, the brush assembly quit turning on the vacuum head. The suction remains good however the brush assembly does not spin. Please advise on this...
    Scholar:
  • 161 Answers
Probably a seized beater roller (the bearings wear out). Just order the new part and replace it and you'll be one your way again. And of course maybe a belt.
Posted on Oct 18, 2013
    Sergeant:
    Champion:
  • 260 Answers
Open and check for belt damage. Also make sre there isn't debris causing this error.
Posted on Apr 16, 2009
Miele vacuum
Check the end caps on the brush roller they might have collection of dirt build up also the unit nust be assembled correctly with no air leakage by the fan so the suction can spin the fan
thiis turbl is made by wessell for Miele the replacement is just as good under their brand for a lot less money
miele turbo nozzle carpet and bare floor brush
Jul 02, 2016 | Miele Vacuums
Brush roller works on carpet setting but not on floor setting. have already cleaned roller. suction is great. just won't do anything on floor setting (all 3 settings)
Check the arms that make the roller go up and down to achieve the settings. There may be something clogged in there.GOOD LUCK FRIEND
Sep 14, 2014 | Electrolux EL8807A Precision BrushRoll...
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Vacuums
Hey everyone, first time on forums. I have a Eureka True Clean vacuum that I found in the garbage. I have disassembled everything, cleaned and restored it. Looks perfect now. Suction from hose is powerful,...
Change the belt on the unit, and adjust the height adjustment until the brushes are just touching the carpet. I know you mentioned the belt looks good, but when you get the new EXT-U belt, you will notice a size difference. Good luck!
Jan 25, 2012 | Electrolux Vacuums
My beater bar is struggling to turn. actually, it appears as though it is the motor that is struggling, as it slows down when going against the pile and the motor labours so much that it frequently fails...
Replace the belt, they should be replaced every 6 to 12 months. A belt may look ok but may have lost elasticity and be stretched out. If your belt is a year or two old it may be an inch or so longer than when it was installed. A stretched out belt may turn the brushroll fine but when it is lowered onto the carpet the belt may slip rather than spinning as fast as needed to properly agitate the carpet fibers.
If the motor isn't spinning properly that could be another problem.
Oct 20, 2017 | Beam Industries 875 Classic Central System...
Motor to my electrolux centralvacuum has burned out .Is it a good idea to just replace motor?
Replacing the motor yourself voids the warranty on the motor (1 year). You can take it to an authorized Electrolux (now Aerus) service center and let them replace generally for only the cost of the motor.
Replacing the entire unit will give you a 5 year warranty on the unit, including motor and fan assembly.
I don't know how old your unit is, but if more than 20 years you might consider replacing it due to updates in the other components and potential of them becoming obsolete.
Aug 26, 2010 | Electrolux Central Vacuum
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
The brush wont turn
Make sure that the carpet selector is on carpet setting not bare floor. It only spins on carpet setting. If carpet setting is engaged and still doesn't work you need a new clutch assembly.
Oct 12, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
Generic problem for all Vacuums
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Electrolux central vac problems
I work on many types of units. If you electric floor brush runs but you have no suction then there is possibly a problem with the relay board that allows you to turn on the suction from the hose handle. This is a low voltage (24 V) switching loop circuit that will cause the 120 V motor in the unit to run.
Inside the wall valve are two brass pins. NOTE: there are 120V valves installed on some systems known as a Super Valve. A shock hazared exists if you work on that type of valve. That being said. In the round portion of the valve you can use a garage hose that has a 360 deg. chrome ring to test the valve. The ring completes the circuit causing the unit to power up and suction at the end of the hose. If the suction is weak, there is a colg in the pipe. If you hear no airflow, the relay inside the unit did not energize or the motor is bad.
To test: go to the unit and turn the switch on the side to "manual" if the unit turns on the motor should be ok. DO NOT RUN THE UNIT without and open valve. In some brands dammage to your motor will occure.
If the unit did not run, look for a small button near the switch. This is a circuit breaker for the motor. If it is poped out and you hear a "click" when you press it in there is most likely motor problems and someone should be contacted for repair.
Hope this helps!!
VR
Mar 07, 2008 | Electrolux Central Vacuum
Electrolux Centralux Vacuum Logo
278 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
