Question about Car Audio & Video
Adding line out inputs for RCA cables to amp
2005 dodge durango factory radio wiring color chart. i can't find a chart that tells what each color wire is for?
  • 655 Answers
Hello ssmotorcity,
Here's a link to modifiedlife's Durango page showing the wire colors.
http://www.modifiedlife.com/2005-dodge-durango-car-radio-stereo-audio-wiring-diagram/
If you are adding a LOC for an amp to drive a sub, you are probably better off using the rear speaker wires, the last four wires shown on the listing. If you are adding an amp to drive all 4 channels, then of course, you need to convert both fronts and rears. The simple method is to tap directly into the appropriate wires and connect them to the line converter. If you do not want to tap the wires, you can purchase aftermarket wiring harnesses that are made to plug directly into your vehicle radio and/or the vehicle wiring harness. The Metra part number for a stock radio harness is 71-6502. It plugs into the radio and provides pigtail connections for power and speakers. There is, of course, a harness that plugs into the vehicle harness itself, allowing you to make the connections without any cutting or tapping of the original wiring.
Hope this helps.
Posted on Apr 16, 2009
Radio reset 2003 durango
Dodge Durango Stereo Removal 2004-2007 - YouTube
? 3:05
www.youtube.com/watch?v=LEuFEXBZobM
Mar 23, 2013 - Uploaded by Factory Car Stereo Repair Dodge Durango Stereo Removal 2004-2007 .... an amp inside tht if stock radio is removed it will not work unless u connect an adapter tht costs ...
Search Results
    images for 2003 dodge durango wiring
Apr 05, 2015 | Dodge Durango Cars & Trucks
Where can I get a radio wiring diagram for a 2005 Lexus GS300? I'm trying to replace the factory stereo that no longer works with an aftermarket Kenwood stereo.
I would just google image search it there will be a lot of pics that nothing todo with it but there will be at least one of what you need
Nov 07, 2014 | OEM 2005 Lexus GS300 Radio / CD Player...
Can you tell me the color of the wire for the inside dome lights
Need wiring diagrams for that
Just remove the lamp cover &
look at the colors,may have to unscrew
the fixture to see them
I would be careful adding to any existing
factory wiring,not advisable
Feb 01, 2013 | 2005 Dodge Caravan
I need a wiring diagram for 05 dodge durango sound and ves systems.
  • 2005 Dodge Durango Car Radio Stereo Audio Wiring Diagram
  1. Car Radio Constant 12v+ Wire: Gray/Red
  2. Car Radio Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
  3. Car Radio Ground Wire: Black
  4. Car Radio Illumination Wire: Black/Yellow
  5. Car Stereo Dimmer Wire: Orange
  6. Car Stereo Antenna Trigger: N/A
  7. Car Stereo Amp Trigger Wire: N/A
  8. Car Stereo Amplifier Location: N/A
  9. Car Audio Front Speakers Size: N/A
  10. Car Audio Front Speakers Location: N/A
  11. Left Front Speaker Positive Wire (+): Dark Green
  12. Left Front Speaker Negative Wire (-): Brown/Red
  13. Right Front Speaker Positive Wire (+): Brown/Yellow
  14. Right Front Speaker Negative Wire (-): Brown/Light Blue
  15. Car Audio Rear Speakers Size: N/A
  16. Car Audio Rear Speakers Location: N/A
  17. Left Rear Speaker Positive Wire (+): White
  18. Left Rear Speaker Negative Wire (-): Dark Blue/Red
  19. Right Rear Speaker Positive Wire (+): Brown/White
  20. Right Rear Speaker Negative Wire (-): Brown/Orange
regards, Tony
May 12, 2011 | Dodge Durango Cars & Trucks
Were do i plug in the RCA cables from the amp to a factory radio? do i need any sort of adapters if my stereo dose not have inn or outputs? and where do i hook up the remote from the amp?
Most factory radios do not have RCA outs, but most will have a remote wire. Usually used for a power antenna option. Your remote wire from the amp could be hooked to the power antenna wire on the factory radio and it would work great for turning on the amp. As for the RCA inputs on your amp, you will not be able to use them without RCA outs on your factory deck. Although most amps offer a high level input alternative and will use the standard speaker level out on your factory deck. This means the rear channel speaker wires from your factory deck will be used to feed the signal to the amp. You will have to check the instructions and manufactorer recomendations for the amp you are trying to hook up. Have fun and good luck!
Mar 09, 2010 | Stingpro ST444 1850 Watts Complete...
I wanted to know the audio wiring chart for a 2004 durango
This is from the manual, please rate my help jhere, thanks.
2004 Dodge Durango Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black and Black/Light Green
Car Stereo Antenna Trigger Wire: N/A
Nov 20, 2009 | 2004 Dodge Durango
I bought a used puch 400.4 for my 1999 dodge durango and plan to use the factory stereo, however ther are no hook ups for rca cables. i heard about line level converters but on the punch 400.4 there are...
Hello riggstr44,
The "pass-through" jacks are outputs that allow you to send the same input to another amp.
Each set of the remaining RCA's handles a pair of channels (2 speakers).
You want a 4-channel LOC like the one shown here:
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?tp=2001
Connect the speaker wires from the factory receiver to the input screw terminals (marked A1 through A8) and run 2 pairs of RCA cables to the 2 sets of inputs on the 400.4.
Hope this helps.
Aug 22, 2009 | Rockford Fosgate Car Audio & Video
Maystar cx475
Ok, I am assuming this is the 600 watt amplifier?
DISCONNECT YOUR BATTERY!!
Supplies needed:
- 8 Gauge power wire (long enough to run from your battery to the amp placement) WITH an inline fuse!!
- Depending on your stereo (if it has amp pre-outs or not) you will either need RCA cables (long enough to reach your amp from your stereo) OR a Line-Out converter AND RCA cables.
- The power lead that connects to your "REMOTE" line on your stereo (long enough to reach from amp to stereo - usually blue)
- A good ground wire ( long enough to reach a metal part of your car from the amp)
STEP 1: Find a spot to run the power wire from your battery - through your firewall and into your car - and then to your amp. (DO NOT CONNECT IT TO ANYTHING YET)
STEP 2: Remove your car stereo and look to see if you have PRE-AMP outs (RCA connectors for an amp on the rear of the unit)
A- if you do, GREAT.. proceed to step 3
B- if you don't.. you will need to get a LINE-OUT CONVERTER - what this does is converts the higher signals from your standard wires on your radio, to RCA style wires to connect to your amp.
B2- you will also want to buy a wiring harness kit for your stereo, unless you want to hack away at your factory wires.. (not recommended) - connect the harness kit to your factory wire harness, wire in your leads for the output converter, and run the other end to your stereo.*
*you will need to know which wires run to the speakers you plan to power with the amplifier
B3 - once the converter is properly connected - proceed to step 3
STEP 3: Plug the RCA cables into the stereo or converter, and run them properly from behind your radio to the amp but DO NOT CONNECT THEM YET.
STEP 4: Connect the REMOTE wire from your stereo to the same wire for your amp . (this enables the amp to turn on/off with your radio.. otherwise.. you will have alot of dead batteries)
STEP 5: re-install your stereo into the car.
STEP 6: Connect the RCA speakers into the INPUTS on your amp
STEP 7: Connect the REMOTE wire to your amp.
STEP 8: Connect the speaker wire from the OUTPUTS on your amp to the speakers you wish to power
STEP 9: Connect the POWER CABLE to the amp PROPERLY
STEP 10: Connect the GROUND CABLE to a metal part of your car (sheet metal, not just a bolt)
STEP 11: Connect the POWER CABLE to the battery cable
STEP 12: Re-connect your Battery
STEP 13: Start your car, and test your radio.
If you have any issues from here.. you need to re-check all of your connections.
Oct 12, 2008 | Car Audio & Video
Amp
if its the factory radio more likely it dont have RCAs ..You will need a 'speaker to line level adaptor" ..This has 3 or 4 wires at one end and RCAs at the other.simply connect a left and right set from behind radio or from rear speakers into left and right sets on adaptor ..then connect your RCA cables side to amplifier using RCA wires.
Dec 15, 2007 | Car Audio & Video
Car Audio & Video Logo
310 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
