Question about Canon BubbleJet i560 InkJet Printer
On XP, do I just delete printer and reinstall from DVD? Or do I need to de-install somewhere in programs or other? Thanks/LIanne
  • 326 Answers
Uninstall from the add/remove tab in your control panel
Posted on Apr 16, 2009
Primero mi lectora Lite-on LH18A1P no leia dvd asi q la desarme y le gire un cuarto de vuelta hacia la izquierda el tornillito de calibracion de dvd. ahora los lee perfectamente, pero no graba dvd, cual...
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 01, 2011 | Lite On LH-18A1P DVD RW Dual Layer Burner
Roxio DE 10.2, always says that a drive is not detected when I try to burn a CD or DVD. I have tried editing the Upper Filters,I tried the PXEngine Fix, and also tried uninstalling and reinstalling Roxio...
Run regedit and find the
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Delete the UpperFiltes. You may see UpperFiltesr.bak but leave this one alone. If it still don't work, delete the LowerFilters. That should fix it. Uninstall than reinstall Roxio. This problem sometime happen when you have another program installed after Roxio.
Jan 05, 2011 | Computers & Internet
I don't have a driver
Looks like Umax wants you to pay for a driver/software disc.
I found this advice, i hope it works for you
go to www.umax.de and download the lpt2000.zip. activate your lpt1 in xp, also in bios to both modes with1.7. delete the windows xp twain files (store them somewhere else), but make sure no other program needs them. install the *.zip files via system/hardware through "add scanner" (or similar) and/or install these *.inf files from there. it took me a whole day to figure this out. hope this helps...after all this you can install the downloadable driver which are not compatible with xp. if it doesnt work right away, experiment for the right order of installation on your system. vista access may not run on startup, but scanning is possible after warmup. [fixed]
Sep 05, 2010 | Umax Astra 2000P Flatbed Scanner
Hi there, I recently had to reinstall Windows XP and of course then reinstall the Airplus DWL-G510 drivers. I accidentally did this whilst the card was still installed in the PC (Which it tells you not to...
If you are not OK with editing the XP registry, then I would enlist a computer savy friend to help you. If you make a mistake the computer will be inoperative and needs Windows XP re-installed again.
The other way is to re-install Windows XP from scratch but make sure the Airplus is card removed first.
To fix your problem using Regedit follow these steps :-
1. Remove the program using Add/Remove Program.
2. Delete the Airplus folder from the Program Files folder.
3. Click on Start - Run and type Regedit (registery editor)
4. Click on Edit then Find and type Airplus
5. Click Find Next
6. When Regedit finds a Airplus entry then delete this entry and press the F3 key to find the next Airplus entry - delete and repeat until all Airplus entries have been removed.
7. Close Regedit and reboot the laptop.
8. Install the Airplus driver etc.
If this doesn't work then re-install Windows XP from scratch, it might be quicker to solve this problem in the long run.
Have fun.
Let me know how things go.
Nov 15, 2009 | Computers & Internet
Attempts to print on HP Deskjet F4280 shut down my programs
Sounds like the drivers are not installing properly. Are you installing through the CD or downloading the drivers from the HP website. Since a lot of the new drivers are no longer supporting XP you will need to download a scrubber utility and delete all of the pre installed drivers and attempt to reinstall through a manual installation of the drivers.
Apr 18, 2017 | HP DeskJet F4280 All In One Printer InkJet
Printer will not stop printing until it runs out of paper
Delete all printers, uninstall related drivers and printer software. I have uninstalled and deleted related folders (but don;'t delete from Recycle Bin in case you need to put them restore them). Boot up and Windows should reinstall correct drivers through the internet. Reinstall photo programs with disk that came with printer.
Aug 29, 2008 | Epson Stylus 880 InkJet Color Printer
Umax2000p
my scenner can't run with winxp
Jan 09, 2008 | Umax Astra 2000P Flatbed Scanner
After clean reinstall of windows xp sp2, hp6110 software will not install properly
does the whole software program show up under:
my computer
programs?
Does an icon show up in the system tray?
Did you install IE7?
Nov 15, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Canon BubbleJet i560 InkJet Printer Logo
old marine
old marine
