Question about Panasonic TH-50PHD7UY 50 in. HD-Ready Plasma Television
Picture warm-up Picture starts off with lines on portion of screen (sometimes half) and then warms up in 5-10 minutes. Started after about 7 years old. Would this be a plasma screen problem or a tivo problem?
  • CERRSC Feb 17, 2008
    I have the same problem and my Panasonic Plasma is about 7 yrs old as well. Model TH-50PHD3. It started with just a slight warm up problem which became a 10-15min warm up problem. After it warms up it function perfectly fine. I contacted the local Panaspnic service center and they wanted $250 just to look at it (assuming I bring it in) if they have to come pick it up add $150 ($400) just to get it diagnosed! I feel this is a rip-off, but feel I am between a rock and a hard place. I tried to contact Panasonic directly and they send me back to the local service centers. It appears to be a power supply issue.
  • Anonymous Jan 17, 2009
    Hello, I have the same problem as well. Mine is a Daewoo 42" Model #42SM and mine starts off with a lines all over the TV. After the warm-up period (10-15 mins) the lines go away. Any thoughts?
abhishek33
  • 1239 Answers
SOURCE: My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Posted on Mar 07, 2009
  • 9 Answers
SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Posted on Aug 14, 2009
  • 121 Answers
SOURCE: 50" Maxent Plasma
you need to have a licenced repair tech come look at it sounds like the inverter is going out its kinda likea ballast for florecent lights
Posted on Oct 28, 2009
  • 1779 Answers
SOURCE: plasma only showing half picture
This is beyond consumer ability to repair. Please have it looked at by a qualified electronics service company.
Posted on Nov 23, 2009
  • 5 Answers
SOURCE: Good evening I have a philips 42 plasma and as
If you care to sell the stand that goes with your tv, please email me at mbreier@optonline.net
Thanks
Posted on Jan 05, 2010
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
White horizontal lines covering picture on Toshiba 51HC85
The set uses a Hyper board inside that processes all signals, it is well known for this issue, board no longer available=reason is quite simple : about a dozen tiny surface mounted filter caps on that board with age dry out, at first it will work after warms up as poor caps regain some capacitance and seem to be ok.
Buy a new set, you can send that board out and have it repaired/rebuilt but the last one I saw which was under extended warranty cost about 200 just for the board rebuild.
In the last 4 years Here on Fixya I have encountered only 2 people who were able with instructions had the skill to remove the board and replace those caps, both were top notch computer repair techs.
Dec 09, 2012 | Televison & Video
Half of my screen is very dull and faded
The Tcon is the most likliest item that will cause that.
Nov 07, 2012 | Sanyo Televison & Video
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
Calapsed picture frame
This can only be a bad soldered on the video module, its better to check for any bad soldered and for any fault on the resistor on the video output module.
Hope this initial info / idea helps.
Please Accept my solution if I solved the issue.
Regards,
micro
Mar 27, 2009 | Televison & Video
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Problems at start
Please email me the model number for the tv so i can better assist you.
Thanks,
Tim Nolan
Experttv@comcast.net
Oct 09, 2008 | Sony KP-53HS30 53" Rear Projection...
VW10HT screen filled with horizontal lines until unit warms up (5-10 minutes!)
I have a similar problem with our projector. It help to reverse the output for some reason. When reversed, all horizontal banding disappears.
Jan 22, 2008 | Sony VPL VW10HT Multimedia Projector
White lines & inverted picture at top of CRT TV image
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
Ed
NC Electronic
Mills Wyoming
Jan 07, 2008 | Televison & Video
Television fault
it is not worth fixing get a new tv
Oct 31, 2007 | JVC AV-27020 TV
Panasonic TH-50PHD7UY 50 in. HD-Ready Plasma Television Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
