Question about Eltax Millennium 500 Speaker
Eltax millenium 500 speaker problem
Hi,have lost treble and midrange on 1 speaker only,both bass still work ok,was wondering if it could be something on the electrical circit board inside or the speaker units themselfs,also were is best place to locate parts reguards james
    Problem Solver:
  • 16 Answers
Some high end speakers have a fuse to protect the tweeter (treble). Reverse the speakers. Does the problem follow the suspected speaker? If so, the defect is most likely on the crossover inside the speaker.
What do you mean by best place to locate parts?
Posted on Apr 16, 2009
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
How to set up a sony ht-is-100 home theatre system to play music cds to get the best sound
"Best sound' is subjective. Giving the hardware the best signal path is the limit of our advice.
If your unnamed CD player has a compatible digital output, use it. I'm sure its manual speaks to that.
With a single midrange and treble-leaning satellites I wonder just how good the system CAN sound, sound-stage-image-wise. Many sub/sat system get away with a solo sub because (in theory) bass is hard to localize but no theory asserts non-directionality for midrange.
When a reviewer has to compare them to something truly bad (TVspeakers) to make them look good, well, it's faint praise...
http://www.stuff.tv/review/sony-ht-is100
"If you're used to listening to tinny, bass-free two-channel audio from your telly's built-in speakers then the improvement the Sony brings will have you thinking your ears have been given a clean with a high-pressure jet hose. Which is a good thing."
Jun 26, 2011 | Audio Players & Recorders
What are the best settings for bass , treble and mid in order to get the best sound
There are no hard and fast rules for setting Bass, Midrange and Treble on your radio. Depending on the type of music you are listening to with your radio, it can / will determine your sound settings. To attempt to set the sound settings on your radio, select the sound settings and set all of them to 0. ( Bass,mid,treble ), then start playing your usual music. With the music playing move the treble setting in single incriments 1,2,3,4 and so. A comfortable setting is usually a 5 out of a total number of 6. Then move over to Midrange and repeat process. A 4-5 out of 6 is usually comfortable. Finally comes the Bass. You do not want to overpower your speakers with too much bass as this will damage them over time. Repeat the usual process and listen carfully for any baffling or distortion as you move through the numbers. A comfortable bass setting is usually 2-4 out of 6. Again I must stress that there is no hard and fast rule for settings. It boils down to the type of music, and what your ears tells you sounds good. What sounds good to me might not be enough for you, or vice versa. I hope this helps! Cheers!
Mar 30, 2011 | Pioneer DEH-4300UB Car CD/ MP3 Player
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
What niles power amplifer would work effortlessly with my bose 901 speakers? i am trying to achieve a deeper bass and tonal level treble for my speakers even at a low volume levle thanks.
The 901 Active Equalizer comes with some bass and midrange adjustment for tayloring them to your environment and taste.
Your question is about personal preference, which none of us could possibly answer.
Since any amplifier worth its salt should just make the sound BIGGER without coloring it, your question is moot. What you want is NOT a quality amp. Maybe an equalizer?
Mar 21, 2010 | Bose 901 VI Main / Stereo Speaker
Bass problems
At the audio mixer settings choose playback and look for something like "for advanced users" or like that. Here you will find the BASS - TREBLE control. In some older audio cards there isn't any selection like that.
Stelios.
Feb 20, 2010 | Inland ProSound 2000 Computer Speakers
House already wired up for wall speakers (2 wires) BUT
Hi...
The 4 wires are 2 for the treble/midrange 2 for the bass.
You can tie the wires in parallel ( one wire from one pair to another in the other pair and repeat) but you need to know how many "ohms" the stereo can handle.
Should say on the back of the rack system
Jan 12, 2009 | Panasonic SC-AK500 CD Shelf System
Logitech r-20 speakers
Hi again andrew63,
There are two possible methods of adjusting the bass and treble output to your Logitech R20 speakers:
1. Hardware - if you feel like experimenting or working with electronic gadgets, you can connect an external preamp with tone control or graphic equalizer between the PC and the input of the speakers/amp; and/or (probably the easiest)
2. Use a software (to listen to your music files/medium) that has a virtual equalizer such the old MusicMatch Jukebox or as an add-on/plug in.
Btw, thanks for asking me to be a Tech Buddy.
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
My speakers sound flat with no highs at all
I am trying to work out if you have damaged the speakers and amp too.
Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine.
Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble.
Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame.
When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
Apr 14, 2017 | Paradigm Audio Players & Recorders
Eltax Millennium 500 Speaker Logo
524 people viewed this question
Top Eltax Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Eltax Audio Player and Recorder Expert? Answer questions, earn points and help others
