Question about Refrigerators
U-Line 75R refrigerator compressor does not turn on
The lights inside the refrigerator is working. The fan does not spin. The compressor does not turn on
  • 67 Answers
Chick the defros timer, replace the defros timer
Posted on Sep 16, 2007
The fan and compressor are both controlled by the temperature control behind the grill. (the control with the numbered dial). Unplug the unit, and test the control to see if it has continuity at the full cold setting. This is a simple and inexpensive repair.
Go to www.u-lineservice.com for additional information.
Posted on Apr 07, 2008
My U-Line mode l15BWC fan and compressor won't work
More than likely it is the temp control (thermostat) it is what controls the on and off
Oct 12, 2012 | U-Line Wine Captain (2015WC) Wine Cooler
2075R u-line Light on but compressor and fan not working DK
Could be the thermostat controller. Here is a link to old U-Line manuals. It has some basic troubleshooting:
http://www.u-lineservice.com/index.cfm?event=Consumer
Check out the thermostat switch and make sure it is good. U-Line tells me this is a very common problem in older models.
Jun 30, 2010 | U-Line 75R Refrigerator
U-line 75R won't cool but light works. What control gets replace
It could be a lot of different things. Is the compressor even turning on?
I sorry to say you may have to call someone on this one.
I hope this helps.
Apr 19, 2010 | U-Line 75R Refrigerator
My u-line 75rfb-00 refrigerator wont get cold the light comes on the motor sounds as if its working but it only gets cool not cold ?
Then you need to see if the compressor is running or is it the fan? You migh be hearing the compressor come on for a short while. The fan might not be running. Replace the fan if its not running
Sep 26, 2009 | U-Line 75R Refrigerator
U-Line outdoor frig not cooling properly
check timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32 don't damage coils
Aug 22, 2009 | U-Line 75R Refrigerator
Refrigerator compressor motor will not run.
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
Aug 11, 2009 | U-Line 75R Refrigerator
Inside fans not running
verify wiring probably lose wire(s) in movement
Apr 21, 2008 | True T-49 Side by Side Refrigerator...
U-line 29RBK Repair
First, reset the breaker. If the unit restarts, you're okay. If possible, change to another good circuit of comparable rating...generally at least 15-20 amperes...sometimes the breakers go bad. You may have a bad compressor or compressor start relay. We can only know about that after the breaker is ruled out as a cause. Oh, and be sure the plug contacts are not corroded. If they are: use a little steel wool to clean them and remove all strands when you're done.
Dec 22, 2007 | U-Line 75R Refrigerator
Lighns on - nothing else
well i have a 75r also with the same symptoms but there's no freezer in this model so I don't know how it could be the defrost timer.
Dec 03, 2007 | U-Line 75R Refrigerator
Refrigerators Logo
669 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
