Question about Denon DMD-M10 CD Player
Can this player have a mains cable and be able to play it without
Does this player have an electricity mains cable
  • Robert Knox Apr 17, 2009
    this is a denon minidisc player dmd-m10
  • 41 Answers
Yes.
Posted on Oct 04, 2009
One day my radio was playing great. I turned it off and now it will not come back on. I have inserted something in the little whole to reset the radio and checked the fuses but nothing happens. The code...
this units have a Flex cable which connect main board to TFT Display, if in this flex cable appears interrupted electrical path, (possible) unit can not start.
If u can't remove power plug connector, remove for 2 minutes positive cable from car battery to make a hard reset of unit.
Nov 02, 2011 | Panasonic CQ-VD6503U Car DVD Player
How to get unit to play without remote
You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
Apr 22, 2011 | Panasonic Televison & Video
It won't play dvd's in color
Please check the type of disc that you're playing.
Generally, if the NTSC format disc being played in PAL Player or vice versa will cause this issue. Please use the NTSC format disc in NTSC player and PAl disc in PAL player.
Please check if the Player is connected to the display device with the correct cables and to the correct jacks.
Please make sure to connect the Component OUT (Red, Blue, Green cables) to the Component IN (Red, Blue, Green).
If you are using the Compiste connection (Yellow, Red and White), please connect the Video OUT of the Player to the Composite or Video IN on the TV using the Yellow cable and Red and white for audio according to the color codings.
Please try with different jacks on the TV to confirm if the issue is with the Jacks on the TV.
Please try power resetting the TV and check if that helps.
Turn off the Player.
Unplug the Player power cord from the electrical outlet.
Let the Player remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the issue is still unresolved, the Player needs to be Serviced at the Authorized Service Center.
Mar 30, 2011 | Sony DVP-NS50P DVD Player
Can two players play call of duty black ops on Wii? can 2 players play, more specifically, Zompbies on CoD black ops on Wii (without resorting to wifi or going online)? if there is no way of two or more...
Sign into a PSN account and launch Call of Duty: Black Ops III. After reaching the Main Menu, connect a second controller. Press X on the second controller to connect the other player online. Once connected, press X again to attach the split screen player.
Oct 30, 2017 | Activision Call of Duty: Black Ops for...
M & S MC602 intercom system locked up
Mine does the exact same thing, except mine isn't set up to change stations from rooms..did you ever find a fix?
Aug 09, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Mar 14, 2009 | Teac PD-H300 CD Player
Dual portable dvd player second screen not working
Sounds like it may be a bad linking cable or connection. Make sure you have cables inserted firmly and correctly. If possible, hook main unit to TV to be sure you are getting proper Video/Audio output.
Dec 23, 2008 | Durabrand PDV-705 Portable DVD Player
Black 80gb ipod Video
Try resetting it. Hold down the Menu and middle button at the same time until the screen gets dark.
If that doesnt work, Restore it. Plug it into the computer and click "restore" when it pops up in itunes. Please note that this will erase all data on the device.
Nov 14, 2007 | Apple iPod MA446LL/A MP3 Player
Sc-HT80 Problem
Hi one solution to your probelom is that the lazer is underpowered.here is a fix it 4 u. A major problem began 2 years ago Some New DVDs would not always play. Message on LED display says "NO PLAY". I discovered today that the problem lies with the laser being underpowered for some DVDs. On the web I found a fix. Warning! Always have someone competent with electricity to fix the SA-HT80 with the following instructions: 1. Remove all disks from player. 2. When door is open slide front door cover upwards to remove. 3. Leave door open. 4. Important UNPLUG FROM THE MAINS! 5. Remove the 3 screws from under the front panel then remove cover screws. 6. Disconnect player from the mains. Remove cover. 7. Once you have removed the cover you will see on left side is the drive parts. 8. Pull out the two flat cables which go to the Drive from the vertical circuit Board(Hold the cable with thumb and forefinger close to the connector and slide the flat cables out of their connector. 9. Remove the screws fixing the drive unit to the base of the cabinet. 10. Now remove drive unit. 11. Placing the drive upright on a flat surface proceed to remove the two screws holding the Plastic bridge that sits over the disk. 12. Also undo the screw on the small circuit board which holds the disk sensor switch onto the bridge and unclip that small board. Remove this plastic bridge over the drive. 13. On underside of drive remove the two small screws from the drive circuit board. You can now gently prize this board loose.(There is some resistance as a plastic clasp is holing onto the underside.) 14. Turn Drive back to upright position. 15. Remove the screws which hold the drive in(Screws go through rubber mounts to cushion the drive). 16. Once you have loosened the drive look at the underside and you will see one flat cable goes to the Laser. Where this cable meets the metal part you will see a tiny device connected on the outside edge of the flat cable. 17. Turn the POT 1/5 off a turn clockwise(looks like a small washer and be gentle with it) I used pointed nose pliers for this. 18. Now reassemble DVD player. 19. Ensure cover is in place and screwed down before connecting to a power supply. This is a guide which you will follow at your own risk. Happy fixing Gerald
Sep 23, 2006 | Panasonic SC-HT80 System
52 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
