Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore icemaker (small cubes stuck in fingers) 1065706
I solved my own problem and want to share with others.
After replacing the motor i watched the harvest cycle for a few hours. Noticed small cubes and ice getting caught in fingers during the ejection process. I removed the 40$ water filter (units with pull out filter will function just fine without it. it's in the manual) and that increased the flow 100% so no more small cubes but i then noticed the one cube getting stuck in the fingers in the same place but not too much to keep the unit from working. I re-leveled the fridge and from then on all cubes dropped each time
catriver
  • 878 Answers
SOURCE: Ice Maker
Charles, these models have a habit of the inlet tube freezing over. Make sure the black tube feeding the trough is clear. You may want to disconnect it from the back and see if you can blow through it. I use hot water in a baster to clear them all the time. Another thing is to check the optics. When opening the freezer door the red optic light on the right should flash 2x with a pause repeatedly. When you close the left hand emitter flapper the light should stay on. If it does this your optics are good. Because of these optics the new ice-maker has to be jumped started into a cycle. Once started you can monitor the fill. Catriver..post back.
Posted on Aug 09, 2006
SOURCE: 550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Posted on Jul 19, 2008
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
Posted on Aug 10, 2008
  • 286 Answers
SOURCE: Cubes in icemaker freeze but will not eject from maker
If your unit is not ejecting the first question is what temperature is it at? It should be 10 - 15 degrees. If the thermostat is set too cold it would never satisfy the thermostat and that is what it needs to harvest the ice. But when you say it keeps cycling do you mean the ejector blade keeps spinning? If it does then the thermostat is stuck in harvest mode.
Posted on May 13, 2009
cj2176
  • 520 Answers
SOURCE: I have a Kenmore refrig./ model# 363.9741714
The problem is actually not the ice maker itself. The problem is the electric solenoid valve in the rear bottom of refrigerator. If you follow the water line on the back of the unit down to the bottom and replace the valve that it is connected to then your problem will be solved. Hope this helps. Good luck cj2176.
Posted on Jul 25, 2009
Looking for a free owners manual download for a kenmore cold spot model#106.50442902. Can't get ice maker to work...water goes through d ispenser......?
A copy of your owners manual can be found here.
10650442902 KENMORE ELITE SIDE BY SIDE REFRIGERATOR Manual Sears...
Although I would say there is probably nothing in this that will solve the icemaker not working. This is a complicated unit and there are several different things that can cause the icemaker to stop working!
First thing to check is that it is not jammed.. Lift the cover and make sure a cube is not stuck in there.
Feb 01, 2018 | Kenmore Refrigerators
Icemaker not getting water
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
Aug 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
How to fix a kenmore ice maker leaking water
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
Feb 20, 2015 | Kenmore Refrigerators
NO ICE, WATER LINE OK,RED LITE FLASHING NEXT TO ON /OFF SWITCH
The Model & Serial #'s would help me refine your answer.
I will assume you have either Whirlpool, Kitchenaid or
Sears Kenmore. The blinking red light should be binking as
a pattern of 2 blinks followed by a pause. then Repeats.
Lift the trap door and look at the icemaker, the 8 little fingers should
be parked at upright and slightly leaning forward towards you.
Carefully check to see if you have ice inside the mold behind and
below the fingers. If you feel a curved surface there's no ice..
Next precisely measure 5 ounces of water and carefully place
the water into the mold. Any where behind any finger.
Wait a couple hours and check if cube have ejected out into your
emptied bin...If after several hours and NO ice, most likely the icemaker has gone Kaput! Order and replace it. For detailed video go to YouTube and watch how to remove the icemaker.
Search using the words: Whirlpool In-Door Ice Maker Replacement.
Watch the video before attempting removal..Tricky.
Feb 20, 2015 | Refrigerators
Icemaker is making ice but it will not drop into container
Ice maker has built in heater to thraw ice alittle so the finger scooper lifts up ice and out. Be sure the ice cubes are not stuck in between fingers cause that will jam it. if you dont see any jam then replace ice maker
Mar 28, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
GE side by side CAN17 ice maker...white ''finger assembly'' that pivots has broken two fingers, and the ice cubes are stuck in the cube dispenser. Any ideas why this happens, and how to fix it without...
You will need to replace the icemaker. The sensor that activates the heat coil in the icemaker is bad. The heat sensor allows the cubes to be released from being frozen to the ice tray. Check ebay for a new icemaker. About one third the price of manufacturer for new factory unit.
Oct 27, 2009 | GE Refrigerators
Ice maker fingers got jammed by a small cube, iremoved jam but fingers remain stuck halfway
Hi.
Press on the half-moon cube dividers, just watch your fingers in case it starts to move. It's jammed, and you can usually get it going again like this.
Best regards, --W/D--
Aug 18, 2009 | Whirlpool Refrigerators
One ice cube gets stuck when being ejected out of the mold
You should try adjusting the ice maker water duration setscrew on the front of the icemaker(under the cover)There should be a pos and neg setting. Just incrementally set to neg and see if the smaller ice cubes will solve the problem. Hope this helps
Jul 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jul 25, 2009 | Kenmore Refrigerators
Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Jul 25, 2008 | Frigidaire FRS26R4A Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
287 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
