Question about Optoma DX605 Multimedia Projector
Optoma Projector DX605 - Screen goes black after about 30 sec to a minute of operating. I'm wondering if there is a filter I should be cleaning, because it seems as though it's an overheating issue.
5 Suggested Answers
  • 5 Answers
SOURCE: The optoma hd72 projector lamp
I had this exact same problem. I have changed bulbs gotten 1000 or so hours from new bulb, changed the lamp driver and gotten about 600 more hours from new lamp driver. New lamp cost me $350, lamp driver cost me $120. Then I read on a page to try and flip it right side up, because I had it ceiling mounted upside down. I flipped it right side up and it works perfectly and has been working perfectly for 2 months now. I know it sounds stupid, but it actually worked for me, and it costs you nothing to try it. For some reason, gravity effects this unit.
Posted on Feb 05, 2009
webkruzer1
  • 17 Answers
SOURCE: My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
Posted on Apr 09, 2009
  • 7 Answers
SOURCE: optoma DX605 hard reset
Have you tried going to Menu>Options>Lamp Settings>Lamp Reset>Yes?
Hope this helps!!
Posted on Jul 13, 2009
  • 14 Answers
SOURCE: orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Posted on Jan 16, 2010
When turning on the projector it shows the Optoma logo but will not boot to the home screen. Is there a way to reload the home screen software?
Depends on the model. If you saw a little fan, then there is a fan problem. There might be 3 fans. 2 square ones and one blower fan. Look for plugs with 3 wires(red/white/black or red/yellow/black). Those will lead to the fans from the mainboard. Occasionally the fan will spin but the tachometer lead will stop reporting the fan status and the projector shuts down. To being with I would clean out the projector fans and ducts thoroughly. That may clear up the issue. Otherwise there is a button press sequence to enable the service menu, but you cannot upload new firmware without special optoma software that isnt available. Another possibility is you have failing filter capacitors in the power supply. Be careful poking around under the hood. There is lethal high voltage possibly stored even when unplugged.
Nov 26, 2014 | Optoma ML300 Mobile LED Projector
Optoma ex530 screen goes dark
possible the condenser lens or light tunnel goes bad.firstly try to clean it, if no helpful, you have to replace it.
Jul 03, 2014 | Optoma DX605 Multimedia Projector
Optoma PK301 lost a color
it is not correlated with bulb
1,the color starts to go out, it become the white and black,the color is disappear.
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as 3 sesame seeds
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | Optoma PK301 PICO Pocket Projector...
Picture is upside down on epson projector
reset to factory default or check vga setting in pc
Dec 17, 2013 | Optoma DX605 Multimedia Projector
Optoma 72 projector goes black after 2 minutes Projector stays on but no picture
Does the lamp go off, or does the "shutter" block the light out.
Mar 22, 2011 | Optoma HD70 DLP Projector
Need power supply unit
Optoma fixes all their own equipment. They have no dealers as far as I know...
This place says they can fix it. They may have parts. Offices in California and Georgia.
Apr 16, 2010 | Optoma DX605 Multimedia Projector
My projector is showing the picture upside down
there must be a switch that controls that so people can mount their projector upside down on the ceiling
Jan 02, 2010 | Optoma DX605 Multimedia Projector
Optoma DX605 hard reset
Hope this helps!!
Mar 15, 2009 | Optoma DX605 Multimedia Projector
OPTOMA EP716
ALSO CHECK YOUR FAN. IF THE FAN OR A HEAT SINK IS NOT WORKING PROPERLY (I.E. THE FAN MAY JUST NEED TO BE CLEANED OR REPLACED, THERE SHOULD BE A SMALL HEAT SINK. IF CLOUDED W/DUST, IT WILL KEEP THE OPERATION SHORT). ALSO CHECK IF YOU HAVE SET ANY TEMPERATURE SHUTDOWN PARAMETERS. IF YOUR LAMP HEATS UP FOR SO LONG AND REACHES A TEMPERATURE THAT WILL AFFECT THE CIRCUITS, THIS OF COURSE WILL SHUT DOWN YOUR UNIT UNEXPECTEDLY. HOPE THIS HELPS...JGUAM
Jan 12, 2008 | Optoma EP716 Multimedia Projector
Optoma DX605 Multimedia Projector Logo
138 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
