Question about Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag
Electrics cut out so often then come back on after a while
This is a seven year old scooter running on the same batteries.
  • 40 Answers
First of all,7 years is a long time for a scooter. Your batteries are probably shot and I would suggest you take it to a service tech to get it fixed. This would be the best way to keep this scooter running.
Posted on Apr 16, 2009
Help with a Pride mobility scooter
Pride Mobility Products
There are 8 different models of the Pride Go Go Scooter. They vary in number of fuses, size of fuses, and number of wheels among other things.
Your manual may indicate the particular model you have. If you no longer have the manual, there may be a model number on it that would assist in finding an online manual.
Here is a way to contact technical support for the Go Go:
https://www.pridemobility.com/contact-us
Here is a troubleshooting site:
Statewide Mobility Troubleshooting Pride Go Go Scooter
Aug 13, 2017 | Pride Health & Beauty
More on Celebrity X motor overheating. Brushes look good. Brake does not seem to be dragging, Batteries are about 5 years old but hold a good charge when not in use for months,
If the motor is overheating, it is drawing far more current out of
the batteries than it is supposed to. Assuming it is 2 x 13v x 33ah
batteries, these are good for about 2 to 3 years on my scooter and 'wheelchair. AGM (absorbent glass mat) lead acid batteries do deteriorate over time due to battery chemistry.
Although the batteries may appear to take a charge
and the voltage 12.6volt x 2 = 25.2 volts nominal, with no load
on them, the motor controller takes a whack of current to get you going.
I have an digital voltmeter/ammeter installed on my Pride XL scooter and I was amazed how much current the motor/motor controller takes from the batteries. 50 to 80amps on startup.
If the battery voltage drops due to the age of the batteries, as the
energy is being used up from them, the current required by the
motor for rotation has to go up, and that will cause overheating of the controller and the motor. It is Ohms law plain and simple
the less voltage available-the more current required to do the
work and current creates the heating effect.
I replace my batteries every two years. Can't take a chance on
being stuck with discharged batteries.
Feb 20, 2015 | Pride Celebrity X 3-Wheel Electric Scooter...
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
Scooter wont run unless it is physically being charged
I think your batteries have died. Are they 2 years old or more?
Jul 31, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
TGA mystere mobility scooter error code 02 battery fault showing without key in ignition
Hi Dont know about Error 02, byt if scooter is less than 1 year old get the people you got it from to fix it under warranty,
Jan 28, 2013 | Health & Beauty
Scotter will lock after running 10 feet
Check the batteries, charger, state of battery charge. Have the batteries load tested. Replace the batteries if over 2 years old and they load test bad
Aug 05, 2012 | Pride Value Line Revo Scooter 3 Wheel
I have the Shoprider Delux scooter.I brought it second hand.I put in a new battery but its not holding the charge. I seem to have to charge it up before any trips out.When its fully charged and I go about...
Yvonne,
When you say that you put in a new battery, I hope you mean new batteries. This particular scooter takes 2 batteries and just changing one will leave the remaining one in poor condition. Make sure that you have replaced the batteries with the correct size and type. This scooter takes 2, 40 amp hour batteries. Sealed gel AGM batteries are preferred. The batteries should have the number 40 on them with a date code. You need new, fresh batteries to have them work properly. A date code tag of A1 indicates the A month(1st month) or January of 2011 (1 is for 2011). If you are not sure of the battery condition a local shop can load test them for you.
There is a possibility with a 5 year old scooter that a worn motor/brake will cause excessive current draw and drain your batteries. A qualified technician can determine this for you with a service call.
Hope this helps.
Mar 18, 2011 | Shoprider Sprinter XL4 Deluxe 4 Wheel...
PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Jul 19, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag Logo
554 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
