Question about Kenmore 73952 Gas Dryer
Replace motor on Kenmore gas dryer
How difficult is it to replace motor on Kenmore gas dryer model #77732792?
  • leannbrooks May 05, 2009
    want to replace motor on kenmore model 76712 and can't finish getting front panel off
jumptrout51
  • 3361 Answers
SOURCE: kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Posted on Mar 27, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore series 80 gas dryer will not heat up
Hi. this dryer has a set of coils that sit on top of the actual gas valve assembly. these coils activate the main and secondary gas valves and if the coil assembly is malfunctioning or, the wires and clips are corroded, the coils will not activate the gas valves to open and close. this malfunction will affect the heating process within this dryer unit.
I recommend inspecting the dryer coil assembly. use a mulitimeter to test for Resistance. you should get a reading of some type of current flow through the wires and, if this is the case, the coils are bad and they will need to be replaced.
This test is actually not needed. the non existing heat is a red flag on its own and, it greatly confirms a major failure within the coil assembly. replacing the coils will fix your dryer.
PLease rate and god bless:)
Posted on Apr 20, 2009
  • 68 Answers
SOURCE: Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Posted on Apr 29, 2009
FixinFax
  • 3085 Answers
SOURCE: I have a kenmore 400 series dryer model no heat
Srart by pulling each thermostat wires and tape them together until you find the bad one. You should have 3 of them to test.
Posted on Oct 25, 2009
erpaalai
  • 999 Answers
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Posted on Jan 24, 2010
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
How easy to replace motor Kenmore kenmore 417.92042101?
Replacing a motor is fairly easy, but they are very expensive. It is often a better bet to just purchase a new machine, because whilst you have the machine that far stripped down, you might as well replace the rear bearing and the front drum slides.
Your motor is $87, so not a bad price. And as yours is a gas drier, it is probably a good bet to just replace the motor.
Parts
Kenmore Dryer Model 417 92042101 41792042101 417 92042101 Parts
KENMORE DRYER Parts ' Model 41792042101 ' Sears PartsDirect
https://www.searspartsdirect.com > Model Search Results for "41792042101"
Shop for KENMORE DRYER repair parts for model 41792042101 at Sears PartsDirect. Find parts, manuals & diagrams for any KENMORE DRYER repair project.
How to Replace a Kenmore Gas Dryer Drive Motor - YouTube
? 4:24
https://www.youtube.com/watch?v=vunod36mWGE
Jan 11, 2015 - Uploaded by Sears PartsDirect
Sears PartsDirect. ... This video from Sears PartsDirect shows how to replace a broken drive motor in some ...
Jan 13, 2018 | Cars & Trucks
I've got a 75732 Model gas dryer and the tub won't spin. It has power (I can hear it turn on), but it won't tumble. Any help would be greatly appreciated
your belt should be replaced and you should ck the tensioner it is a flat spring with a plastic wheel on it the belt goes around the wheel on your motor and the tesioner takes up the slack. make sure to turn your power off first. It is not difficult to fix. Only replace the tensioner if the wheel on it is wobbly or sticking.
Aug 08, 2010 | Kenmore Dryers
Gas kenmore dryer
It could be a couple of things, but I would start with the flame sensor. Different models work differently.
Jan 03, 2010 | Kenmore 74962 Gas Dryer
Oct 25, 2009 | Kenmore Dryers
Cost of a motor for a kenmore dryer
get the model number from inside the dryer door,then go on ebay and see what you can find,i have found dryer motors for as little as $30-mike
May 22, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Kenmore 73952 Gas Dryer Logo
136 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
