Laptop key board are messd up
Some one has moved the keys around on my laptop board and i woul like 2 reset them and have tried the regonal settings
  • adi May 11, 2010
    did someone move the keys on your keyboard?
  • Mike Greenly May 11, 2010
    Have you tried to run office diagnostics? You can access this feature by going to the Help menu option and selecting "Office Diagnositcs" (from within any of the Office 2007 products).
  • 53 Answers
If you have changed the keyboard type in 'regional and language options' you can manually pull of the keys and stick them back on where they should be. It sounds like someone has done that to your keyboard so no regional setting could fix this.
Instructions for Windows Vista
Click Start and then Control Panel In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner) Open Clock, Language, and Region Click on Regional and Language Options. Click the Keyboards and Languages tab and then click Change keyboards. Under Installed services, click Add. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Posted on Jul 28, 2009
2011 Jaguar XF. Was running fine, parked it. Returned, engine turns over will not start.
try a battery reset.ie. disconnect battery neg terminal and leave 10mins reconnect and retry lock and unlock then see if the smart key is regonized if not check the smart key battery specialy the contacts it may be the key is not been reconized but if it cranks but not start may be a engine management system or fuel delivery problem if it has asked to insert smart key the key battery is poss flat.
Nov 05, 2016 | 2011 Jaguar XF
The keyboard doesnt work properly. when i type it moves around the screen and randomly closes things down
it seems that any key is stuck in the key board, if you can open it & clean the membrain it may fix the problem or you can replace the key board.
Sep 26, 2011 | ASUS Eee PC 904HD
Clean unable 46 dispaly
Try to reset DCP printers without numeric keypad.
Follow this:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Jan 14, 2011 | Brother DCP 130C All-In-One InkJet Printer
Brothjer DCP-540 CN - unable to clean 46 what do I do?
Follow this:
Don't forget to vote Thanks!!!
Jan 05, 2011 | Brother MFC 420CN All-In-One InkJet...
I can not log onto my zoom router.....forgot my pass key for network need to add laptop
1. You will have to reset the router to factory default and run the setup wizard using your set up CD and create a new key.
Set up your laptop on the router using either the MAC address or a new password key.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 27, 2010 | Zoom (56600000) Router
I am failing to remove the Bios password in Dell Latitude D630
This should be pretty easy to do.
1. Reboot your laptop and select F2 to go into the BIOS settings. You'll need to be quick or it will boot to Windows.
2. Use the --> arrow key to move to the Security page.
3. Arrow down to the Set HDD password and press Enter
4. Enter your current password
5. Select the Enter key twice to enter no password
6. Select the F10 key to save and exit.
Dec 17, 2009 | Dell Latitude D630 PC Notebook
Don´t reconice key board, mause ok
UNPLUG THE KEYBOARD,THEN PLUG IT BACK IN. XP SHOULD REGONIZE IT
Apr 14, 2009 | Computers & Internet
Laptop keyboard typing problem
You need to go into control panel and change from american key board in regonal and language options it is easy to do just pick from the list and click apply. You should also check you have everything else set up properly while you are there (like time zone).
Jan 10, 2009 | Acer Aspire 5670 Notebook
Security system
try to unlock driver side door with key, resets sets alarm
Dec 13, 2008 | 1995 Cadillac Fleetwood
Number keys not working
you can try to reinstall them if the little white latch is still in place and broken
put the key right over where it goes make sure it is spaced and straight and push straight down you should feel a slight click and it will stay if the clips are broken you can order a new key board pretty cheap
Jul 31, 2008 | Computers & Internet
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
