Question about Samsung Washing Machines
Need a wiring diagram for Samsung B1415J washing machine
Hi - I need a wiring diagram for Samsung B1415J washing machine.
Possible?
5 Suggested Answers
gwshaw71
  • 83 Answers
SOURCE: VBXR1090DBWW top load wahsing machine
your problem is your lid switch
Posted on Dec 07, 2007
IFIXALL
  • 868 Answers
SOURCE: How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
Posted on May 20, 2008
  • 3 Answers
SOURCE: I need a wiring diagram for a ipso we-181 washing
most washing machines have wiring diagrams tucked or taped in the control area of the washer look for a folded paper this may help
Posted on Oct 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: Wiring diagram for GE Washing machine WWA8852 RBMWW
In the console of your unit there is a service manual. The wiring diagram is inside.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Im not getting power to my machine?
not sure how much a wiring diagram will help. but you should check continuity across your pump (if this circuit is not closed the machine will not power on). if you replaced a fuse on the board, it is possible that more faults on the board have occured (there are two fuses on the newer model boards)
Nov 12, 2013 | Fisher and Paykel GWL11 Top Load Washer
Hi\r\nIve got a samsung big wash B1415j that has a bad vibration under load the belt came off and is fairly worn and about 6 years old
First have the belt changed!!! It will only keep coming off.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person ( I am assuming your washer is front loading).
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 06, 2011 | Samsung Washing Machines
Hello could i possible ask where to find a wiring diagram for miele professional laundry machines. only they ask you to go on a course and they are not running any in the near future. the unit in...
Hi sales55335,
Here you go, the first of 5 different wiring diagrams you can get. Let me know if you need another type.
Kind Regards :-)
If this solution helped you, please vote positively.
May 06, 2011 | Miele Washing Machines
I have a samsung big load B1415J and when the program reaches the spin cycle, it just stops completely.. any ideas what this may be?
My best guess without being there is that you have a belt that sliped or broke off. Open the washer up and look around (usually from the back of washer). The belt should be located at the bottom of the unit and should sit on a type of pully system. If you cant tell you can try to dry run it with back off and watch what happens. Hope it help Let me know what you find.
Dec 22, 2010 | Samsung Washing Machines
Samsung bigwash washing machine b1415j
on the front of the machine at the bottom is a panel you can take off to clean the filter. take this off and there is a plastic cord you pull to release the door! hey presto
Oct 23, 2008 | Washing Machines
Washing Machines Logo
155 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
