Question about Hoover Dryers
Hoover vhc392t condensor dryer. Stops after 10 mins
Hi I have a Hoover vhc392t condensor dryer. After ten minutes it just stops working. Can u give me any suggestions? thank you.
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
a00gha
  • 21 Answers
SOURCE: dryer runs for ten minutes then stops
If it's electric and the discharge hose is plugged with lint, a thermal switch will shut it down when it reaches a preset temp. (that's too hot). Also check for lint in the discharge pipe of the dryer. It is possible that the switch is bad. It will be marked at the temp. it shuts down at. Connect switch to an ohm meter, put it in the oven (but not the meter) and make sure it's opening at the proper temp. If the switch is opening at too low of a temp. replace the switch. Bob Taylor
Posted on May 25, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
SOURCE: I have a Hoover vision hd b energy condensor dryer
My engineer is coming out, didnt realise i had to pay for this assistance,it made out on the ad that someone was able to help you by giving advice,it didnt state you had to pay, for i thought forget it.
Posted on Aug 27, 2009
  • 161 Answers
SOURCE: hoover tumble dryer vhc392T drum not turning.
check the belt to see if it is broken. check the drive motor to see if it is working.
Posted on Jan 10, 2010
Testimonial: "when i can find out how to check the belt i`ll let you know. "
How do I access the cable connectors on a Eichenauer 40004314 heater thermostat unit on a Hoover VHC392T
did you take the panels off to access the Thermostats and heating unit?
Aug 10, 2014 | Hoover Dryers
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
My hoover dryer vhc392t makes a loud squeaking noise when in use can it be repaired
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 23, 2010 | Hoover Dryers
Just moved into a house in Singapore with a Hoover D6786 dryer. It starts up and spins but repeatedly stops spinning after only 5-7 minutes. Clothes will not dry. What's up? Thanks for any help.
This is normally the sign that the electric motor start/run capacitor has gone faulty: the special motor start/run capacitor, usually around 4 to 10 uF / 450v, helps the motor during the stop/start sequences which require higher torques.
Aug 05, 2010 | Hoover Dryers
Goes on works about 10 minutes. stop.try to turn
Problem is the motor is going bad. Sometimes the motor can almost cost as much as a new dryer. An excellent little dryer that will last and work ghood for you is Roper, made by whirlpool. Any Lowes store has these. Hope this helps.
Mar 19, 2010 | Frigidaire Dryers
I have a Hoover vision hd b energy condensor dryer mega 9kg. The start light and empty water light flash at the same time and dryer stops. I have emptied the water container and the filter and still the...
Aug 26, 2009 | Hoover Dryers
Dryer stops working after 10 to 15 minutes
i have a kenmore electric dryer, replaced all major parts, and it still stops after 15 - 20 min after being on help please dont know what to do next cant afford a new dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Nov 11, 2008 | Kenmore 63942 Dryer
Dryers Logo
106 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
