Printer HELL !! need assistance
Hi, my printer stopped working recently and so i have replaced the printerhead and put in new ink cartridges. I've installed the drivers and yet it will only print blank pages. The printer goes through all the motions of printing but the pages are blank.i've uninstalled and reinstalled everything and checked the installation of both the printhead and the ink cartridges and all seems fine so i'm totally confused.None of the test print outs work either so hopefully you will have some idea..fingers crossed x.I am running windows vista home premium and it is a canon i450 inkjet printer.
  • Anonymous Nov 03, 2007
    I installed a new black ink cartridge on my dell 924. Printer doesn't identify that it has been replaced with a full cartridge.
  • Anonymous Nov 12, 2007
    I have the same problem, even reinstalled everything to make sure.
Hmmm sometimes new printheads have tape or covers on them try removing and checking them.
Posted on Sep 15, 2008
Illustrate on how to replace the ink cartridge on printer
Posted on Oct 28, 2007
SOURCE:
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
I replaced the black 100xl ink cartridge in my printer, it is almost full, and was working fine before, now it will not print and only gives me blank sheets. the colored cartridges work fine just not the...
Try to do the Deep Clean Printhead function on your printer. On the printer touchscreen, touch Ink Levels > More Options > Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please contact the Lexmark Technical Support Center or point your browser to http://bit.ly/lFKDzs for online technical assistance.
Sep 12, 2011 | Lexmark Prospect Pro205 Wireless...
My esp 3 kodak printer now has a printerhead problem after a year of use. When the printer does it's power up check I get a error with the ink cartridges indicator light lit up. When I remove the ink...
Your printer needs a service, in other words the waste ink sponges need to be cleaned and dried. They then need to be replaced and the printer reassembled. Then the Epson counter resetting software needs to be installed.
With this software the printer can be set to zero, it will work perfectly after this bit of attention.
It is a good printer, it's nothing that can't be repaired.
A computer technician will be more than happy to service your printer for you.
All the best!
damnor01
Feb 01, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black ink does not print
If your printer have a separate printerhead with the cartridge just try to replace the printerhead of that printer it is because the printerhead have a problem on that.
May 28, 2010 | Brother MFC 240C All-In-One InkJet Printer
Will not print---all I get is a blank paper
Try to check the ink of your printer that they have more ink inside. Or els just check the printerhead of that printer its maybe that was a problem for that. If they could not print at all after this solution just change your printerhead it is because that was the problem. If your printer are using the built-in printerheat from the cartridge just replace the cartridge of what color are did not print but if your using separate printerhead of your cartridge just only replace the printerhead only.
May 27, 2010 | Dell 926 All-In-One InkJet Printer
Canon smartbase MP360 "put in cartridge" does this means buy a new in this case printerhead. The printer was printing fine before this error message came up and printing stopped. Amazing another clean...
Print heads cans wear out. Put in cartridge sound more like a low ink level. Check ink levels and reseat the ink cartridges. Still no? I'd suggest having the print nozzles checked by a repair center or Canon.
Oct 05, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Printing gives only blank pages...
Maybe you need performance a preventive maintenance if you know how great, if not you can call a Printer tech in your area.
May 27, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Printerhead is not installed.
What you will need to keep in mind is that the ink cartridge contains liquid ink, once opened, can and will evaporate. First, wash you hands with soap and water to remove excess finger/hand oils. Use a clean, moist, paper towel, make sure you ring out the excess water from the paper towel before you begin. Remove cartridge, gently wipe the towel over the contact's pad, and the nozzel tip. Use a dry towel, and patt dry, reinstall. and run an alignment pattern test.
Note: If you do not see an ink trail on the paper towel, The Ink has dried up, and you will need to but a new cartridge.
Note: do not touch the Cartridge GOLD contacts, with your fingers, finger OIL will clog the jet pours, and cause them to corrode.
May 07, 2009 | Canon PIXMA MP610 InkJet Printer
Open Questions:
646 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
