Question about Amana ARGS7650SS Gas Kitchen Range
MY AMANA OVEN DOES NOT WORK. THE TOP BURNERS
MY AMANA OVEN DOES NOT WORK. THE TOP BURNERS STILL WORK JUST NOT THE OVEN. i CAN NOT REMEMBER IF IT SHOULD CLICK WITH THE ELECTRIC START LIKE THE BURNERS. HOWEVER IT IS NOT CLICKING NOW (JUST NOT SURE IF IT EVER CLICKED OR NOT), I WAS THINKING IT MAY BE THAT THE IGNITOR IS BAD OR SOMETHING. WHEN I TURN THE KNOB, NOTHING HAPPENS. I DO NOT SMELL GAS EITHER (NOT THAT I AM AWARE OF ANYWAYS). PLEASE HELP.
  • Anonymous May 19, 2009
    We have an Amana Model #ARG7102W that the oven does not work. The top burners and broiler work, but the oven does nothing. It will not work at all, we do not hear any gas or smell any gas. Have any idea what the problem might be? Could this be an ignitor problem?
    President:
  • 1,865 Answers
Possibly ignitor coil defective
Posted on Apr 16, 2009
How do i remove top of my amana gas stove
Most range tops for gas appliance can be lifted up by hand.
You may have a set of screws located just under the top just above the oven door. You should open your oven door and look up at the bottom of the range top to see if there are in fact any screws, if so remove them then lift.
If no screws you may need a small flat screwdriver to help lift the top. It does have a couple of snap clips that will hold it firm but they are just to hold it from moving during normal use.
Remember to remove your burner grates first.
Aug 07, 2010 | Amana RanARG7302 Gas Kitchen Range
I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 | Amana Ovens
Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Oct 03, 2009 | Amana AGDS902 Gas Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Bottom oven won't turn on;
85% of these are usually the ignitor getting week and not allowing the gas valve to open prideapplianceser@sti.net
Dec 31, 2008 | Amana AOGD2750 Gas Double Oven
Amana Range ARG7300W
yep open the oven door unplug the range remove the racks on the bottom liner should be some screws remove them then take the liner up and out if there is a flame spreadder on the burner tube remove it at the back of the burner bar should be the ignighter most new ones are generic you just cut the wires on the old one and splice the new one on with cerramic wire nuts make sure the wires are away from the burner bar reverse dissambily turn oven on should light within 30 secs if ya pluggedit back in
Dec 29, 2007 | Amana RanARG7302 Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
570 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
