Question about Plumbing
I need an installation manual
WHERE CAN i FIND AN INSTALLATION MANUAL FOR A WATER RIDGE FITCHEN FAUCET #205674
  • 88 Answers
Call the customer service line (866) 789-2273
Posted on Apr 16, 2009
Franke faucet FFPS200 has extremely low water pressure over the last few days. Same thing happened to exact same faucet in second home. How to repair?
You can check out the installation manual here that has a parts breakdown: https://s1.img-b.com/build.com/mediabase/specifications/franke/512399/ffps200_installsheet.pdf
Be sure to shut off the water below the sink prior to doing any disassembly.
Best of luck
Feb 24, 2017 | Franke Plumbing
Wateridge Olivia. Where can I get a manual?
Customer Reviews: Water Ridge Pull Out Kitchen Faucet
www.amazon.com/Water-Ridge.../B00O2AGROM
Amazon.com, Inc.The older Water Ridge faucet had a 6 page manual; it seems the company .... me a new Olivia Pullout Kitchen Faucet by WaterRidge' Dual Function Spray Head ...
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed ...
? 3:21
https://www.youtube.com/watch?v=wsreMTL_whc
Apr 19, 2013 - Uploaded by HillBrosReviews
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed Nickel .... gave me a new Olivia Pullout Kitchen Faucet byWaterRidge' Dual Function Spray ... They sent a hose... with nodirections how to replace the defective one.
Dec 18, 2015 | Plumbing
What is causing electric tankless hot water heater to be needing red button reset often?
PDF]Tankless Electric (RTE) Troubleshooting - Rheem
www.rheem.com/docs/FetchDocument.aspx?ID=87d15e35-5adf-4e9f...
Tankless Electric (RTE) Troubleshooting. Technical Competence .... For four chamber units (RTE18 & 27) go to paragraph 4T. 9. Conduct OHMS resistance ...
Rheem RTE 27 Series ' Use and Care Manual
https://www.manualowl.com/m/Rheem/RTE-27-Series/Manual/296033
Rheem RTE 27 Series ' Use and Care Manual - Page 1. Use & Care Manual Electric Tankless With Installation Instructions for the Installer Water Heaters The ...
Sep 06, 2015 | Rheem RTE 27 Tankless Electric Water...
Water Ridge kitchen faucet model FP4A4107NP does not swivel between sinks. I thought they all could be directed into either side of a double sink?
Did you install the faucet without using the top mounting plate? This could cause no spout swivel.
Dec 26, 2014 | Plumbing
I need anInstallation Manual for Grohe Concetto faucet..where can I find one?
contact the plumber and have him fix his mistake the faucet came with instructions . what did he do with them
Oct 16, 2014 | Grohe 3427 Concetto Single Hole Bathroom...
Handle will not turn water off
single cartridge? pull old one, flush some water through empty valve then install new cartridge. once installed, make sure the horseshoe clip is properly inserted to keep the stem in. once the clip is in right, there is a chrome tube with a ridge that slides over the barrel and the clip. the ridge acts as the stop for the handle. also make sure there are stops inside back of handle to hit the ridge on the chrome tube. the plastic inside the handle may break off allowing the handle to spin. the stem unit/cart may also be installed 180 degrees out of place. pull the lock clip and use the remover tool that came with new cart to rotate it 180 degrees with water supply turned off.
Jun 17, 2013 | Moen & One Handle Tub & Shower Faucet
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
Aug 29, 2012 | Bosch AE-9.5 PowerStar 1.5 GPM...
Instructions for the installation of a Delta 470
Here is the owners manual and installation instructions for your particular faucet:
Delta 470
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta Model 470: Signature Kitchen...
Just got the Haier hdt18pa portable dishwasher
You have to buy an adapter for the faucet that allows the hose to hook up. You an get it at any hardware store. It's easier to get a dishwasher installation kit and just hook it up permanently.
Jul 17, 2008 | Haier HDP18PA Stainless Steel...
Plumbing Logo
2,117 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
