Question about Samsung LT-P227W 22 in. HD-Ready LCD Television
Samsung LT-P227W, Will not power up
I had a power outage and now my tv will not power up. i left it unplugged for a couple of days; but it still will not power up. Is it possible to get a copy of the service manual
  • renata_ellin Apr 16, 2009
    Yes, it was plugged into a surge protector.
    ok, thank you
  • 84 Answers
You might of blew the power supply in the tv. I'd take it to a shop and have them look at it. was it plugged into a surge protector?
Posted on Apr 16, 2009
  • Daniel Neaman Apr 16, 2009
    Weird. I would definately take it to a shop. It has to be the power supply.
Why does my TV keep turning off
It is embarrassed by the programming available to it.
All kidding aside, this Samsung site offers some possibilities, a sleep timer, cable box failing to provide output, etc.:
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=28929&modelname=LT-P227W
Oct 04, 2017 | Televison & Video
My sansung tv ....dose not turn on it makes a beeping nosie and turns off the led light turns red .....any chance any one ones wuts wrong
Most common proble is Bad Capaciotrs on Power supply Board they will be vented or swollen on Top 1000uf 16v 2200uf 10v 3300uf 10v
Samsung Parts 1-800-627-4368
PTS 1-800-844-7871 this company rebuilts boards
May 31, 2011 | Samsung LT-P227W 22 in. HD-Ready LCD...
I have a 50" plasma
I can say from experience that it will. The plug type may be a little different, but the tv should be rated for 50-80Hz and you will be fine. For the plug you can just get an adaptor.
Please rate if this helps! :D
Mar 09, 2011 | Samsung LT-P227W 22 in. HD-Ready LCD...
Samsung LCD TV series 5 240Vac, 50Hz will it work with 60Hz?
no only the voltage is critical.the only point is you have to select right counrty and tv sound and picture system on setup menu!
Jun 11, 2009 | Samsung LT-P227W 22 in. HD-Ready LCD...
Menu Mode
PRESS THE DTV / TV BUTTON TO GET TO THE MENU MODE.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 20, 2008 | Samsung LT-P227W 22 in. HD-Ready LCD...
Change the vertical frequency to 60HZ on Samsung LT-P 227W
I'm sorry to say that this LCD is for Standard NTSC, HD-ready, PC-ready only and will not work in Europe unless you can get some NTSC signal. There is not way to change the internal settings because you will also need to change the tuner and many other parts. At this point the cheaper solution will be to buy a multisystem LCD that will work with PAL and NTSC signals.
Jun 02, 2008 | Samsung LT-P227W 22 in. HD-Ready LCD...
TFT -LCD Samsung LT-P227W
BY UNPLUGGING YOU RESET THE TV. SOUNDS LIKE IT IS GOING INTO A PROTECT MODE IF THE STNDBY LIGHT IN FRONT IS NOT FLASHING ITS PROBABLY A POWER SUPPLY PROBLEM IF IT IS COUNT HOW MANY FLASHES THAT WILL BE AN ERROR CODE
Feb 22, 2008 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Tv won't come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Nov 07, 2007 | Televison & Video
The unit will not power up. I tried using a different power cord to see if the old cord was bad. A small red light turned on for afew seconds, I heard some beeping, then the red light went out.
Take it back to the store you bought it from.
contact Samsung about this model. and politely demand a recall/file class action claim, or for the manufacturer to describe this model as a 1-3year disposable LCD TV
Oct 19, 2007 | Samsung LT-P227W 22 in. HD-Ready LCD...
No Power
This set has two boards in it, not including the panel which has the ballast attached. The power supply creates the voltage, one of the voltages may be missing. If the power supply is working correctly, then, the problem may be in the main. The main is the control of the set. On an LCD set, this problem seems to be easy to diagnose, but, it could be any of the three circuits that cause it.
Apr 08, 2007 | Samsung LT-P227W 22 in. HD-Ready LCD...
Samsung LT-P227W 22 in. HD-Ready LCD Television Logo
544 people viewed this question
Jerry Greenberg
Jerry Greenberg
