Question about Garden
Lawnmower starts and goes for several minutes but then cuts out
    Sergeant:
    Champion:
  • 260 Answers
Sounds like its starving for fuel. Clean air filter as well.
Posted on Apr 16, 2009
Have trouble restarting engine (Briggs and Stratton) after stoping to empty grass. Engine is off for several minutes it will not start.
bad valve seat will have to take in have valve job done cost 60.00 dollars do you really want to do this or in my case buy new lawnmower
Aug 21, 2014 | Garden
Weedeater 300 series lawnmower
which engine does it have look where the govern spring
attaches to the throttle where it hook to the tang it is bend
able have to be careful they only should be at 3600 rpms
Oct 15, 2017 | Garden
Lawnmower keeps cutting out
drain out the fuel and try fresh fuel gas is only good for 30 days in small engines
Mar 27, 2012 | Garden
I have a lawnmower that is hard to start, and once it gets going it will run for 5 or so minutes and then bog down and cut off. It needs to rest for about 10 minutes and then can be started once again for...
sounds like its flooding itself out
Carb problems can be a bear, I would check the flote at the bottom of the carb it may need to be cleaned possibbly oiled and somthimes the even get a hole in them
Jul 29, 2011 | Garden
My lawnmower starts fairly easily and will run for several minute but then stops and I am unable to get it to start again without leaving it for 5 - 10 minutes. Any suggestions as to where the problem...
It could be overheating. Check the immediate area around the engines cooling fins and make sure any debris or bugs nest, grass clippings, grease etc. are removed. Also make sure there is no debris in the top housing near the flywheel.
May 27, 2010 | Garden
I have a husqvarna 172 ride-on lawnmower. Running
This unit probably has a safety switch built into it and it could be below the gas tank. If this switch isn't adjusted properly then it's designed to cut off the motor. I think you should concentrate on that before attempting anything else.
Aug 02, 2009 | Garden
Sluggish when started, light smoke
check carb an get a can o sea foam
Jul 28, 2009 | Garden
Lawnmower cuts out on fast idle + runs rough
REBUIld carb it is dirty jet is clogged
May 25, 2009 | Echo Garden
My lawnmower engine cuts out
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Apr 12, 2009 | Garden
Requires several times just to get started and then runs fine for about 5-minutes and cuts then cuts out on its own. Then have to wait for about 10-15 minutes to start again but still requires several...
The most likely problem is the ignition module. It is probably going out. when a bad ignition module gets hot from use, it stops working, which kills the lawn mower since there is no spark. Once it cools off it sometimes works. This can be a some what costly part, $60 - $80. You might want to take it to a lawnmower repair shop and have them check it out, since there are other issues that could be the cause to your problem. If you have a spark tester, you could test the ignition module to see if you get spark, both before you start the mower, and after it quits on you.
Mar 10, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
