Question about Yamaha RX-V2200 Receiver
Yamaha RV-V2200 without power loses settings under 24 hours
I purchased a Yamaha RV-V2200 receiver in 2001 and it's worked well for almost 8 years, but now it's losing settings. In Florida we receive a lot of lightning and associated power problems, so I use a wall switch to disconnect power from my AV equipment when I'm not using it. The manual states that settings may be lost if disconnected for more than one week. Now it loses settings in less than 24 hours.
Does anyone know if this memory is powered from an easily replaceable battery or if it would require soldering in a new battery or capacitor?
  • ANTHONY TREVINO
    ANTHONY TREVINO May 11, 2010
    Please verify the actual model of your receiver
  • Yamaha Master
  • 5,158 Answers
It could be a battery, a bit like the type you get in watches. But I reckon it's a memory retention capacitor that has failed. These are small looking things that look like electrolytic capacitors that have been squashed from above. They appear to have a working voltage of around 5.5 volts too. I am enclosing a picture of one, though it could vary in style. You might find it near the main display of the unit.
Yamaha RV-V2200 without power loses settings under - memory cap-ktgjxfmx1nzpgrd54qfptmsf-1-1.jpg
Posted on May 03, 2017
5 Suggested Answers
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
SOURCE: Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Posted on Oct 17, 2007
  • 4234 Answers
SOURCE: yamaha rx-1500 av receiver
The unit is in protect mode. There is a problem with the last stage of the amplifier section and the unit shuts down to prevent further damage. The most common cause if this is shorted output transistors. If you are comfortable with soldering, you should be able to repair this. Check the transistors attached to the heatsink for a shorted condition. Replace them in pairs.
Keep us posted.
Dan
Posted on May 20, 2008
Gurudristi
  • 98 Answers
SOURCE: 4 ohm speakers with 8 ohm receivers
Please check with the manual of your receiver whether it is capable of running 4 ohm speakers.
if yes, then please go ahead, you will not loose any Sound quality. Sound quality will depend a lot on the performace of the speaker as well as the frequency range it can deliver.
If no, please do not connect. Though, you might be able to play and listen to the music, but it will overload your receiver!!
If you are not sure, please let me know the brand and model of your receiver and I can check for you.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 06, 2009
Yamaha receiver will not connect to Airplay
I have the same problem, it seems the airplay connection is easily lost, it never plays for longer than an hour without itunes losing the receiver, then i have to reset the receiver so that it appears in itunes again, very annoying. I spoke to Yamaha and they are not aware of any issues but clearly there is one. A quick workaround is to bring the receiver up in a browser by typing in its IP address, go to IP Address tab and simply apply without changing anything, this causes the receiver to initialize its network function as you will see the amp resetting and it will then appear in iTunes. This doesn't work through the units setup without changing settings and then changing them back again. Hopefully this is just a glitch that will Yamaha will fix in the next firmware update, I am running 1.14 update.
Sep 28, 2012 | Yamaha RX-V473 5.1 Channel Network AV...
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
We have just inherited a Yamaha RV-X592 Audio Receiver and have tried all the remote codes listed with the universal remote that we purchased. I have found two listed codes that turn the reciver off, but...
You need a learning remote or a "Logitech Harmony" or a "Universal Remote Control" (Brand name) Yamaha uses "Discrete Power Commands"
You will not find those in any remote under $70 or $80.00
If you don't want to spend the money, program the Yamaha's Remote to control your devices. It will control all features and functions, it will just take some time to program. Hope this helps
Sep 26, 2009 | Yamaha RX-V592 5.1 Channels Receiver
I can't get my cable remote to work with my RX-V2200. Are the new universal remotes going to have the same problem?
You need a remote control that can send "Discrete" commands. One for "on" one for "off". "PC programmable" or "learning" remotes will do the trick. "Universal Remote Control" or "Harmony/Logitech" are a couple that have many to choose from. Prices range from 80 to 1,000.00 depends on what you want it to do. If you need some more help, post a comment and I will be glad to help you further.
Sep 23, 2009 | Yamaha RX-V2200 Receiver
Need to know how to hook up a soundcraftsmanA2502 amp
http://www.yamaha.com/yec/products/productdetail.html?CNTID=200218&CTID=5000300&RLTID=1505&DETYP=RELATION
Jul 31, 2009 | Audio Players & Recorders
While watching blue ray, the receiver loses the Signal
check the continuity of the AV Cables and check for any loose connection/dry solder in the connectors
Jul 13, 2009 | Yamaha RX-V861 Receiver
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
SOUND NO PICTURE
Hello, You have a high voltage section problem I would not suggest fixing this set on your own. You will need to take this set to the shop. Because there are no user repairable parts inside of the set.
Sep 10, 2007 | Sony KV-36XBR400 36" TV
Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Jun 06, 2007 | Yamaha RX-V630 Receiver
Yamaha RX-V2200 Receiver Logo
118 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
