Question about Toshiba Satellite A135-S2246 Notebook
DVD drive won't work
I've got a Toshiba Satellite A215 S4757 laptop with a Pioneer AND DVR-K17LF Driver that won't identify the DVD drive when I install a disk. The only drive through "Computer" (I have Vista) that it recognizes is C drive. How can I install/fix the DVD/CD drive so I that I can burn DVD/CD's again?
I have a Sony laptop, model PCG-5J2L. DVD Pioneer
1. Try System Restore to rollback ur settings.
2. If it don't helps, u can update the drivers through internet!
tell me if it helps...tc! :)
Jan 05, 2010 | Toshiba Satellite P105-S9722 Notebook
Toshiba Satellite P205D-S7479 Drivers for DVD-ROM
Download new driver files of pioneer dvd drive fron internet.
Apr 17, 2009 | Toshiba Satellite P205D-S7479 Notebook
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Help my Pioneer DVD-RW DVR-k17LF ATA Device isn't working
this is a hardware device failure
the drive has become defective and will need to be replaced
or it is not making good contact where it plug in at
electech
Oct 30, 2008 | Toshiba Satellite A205-S4607 Notebook PC
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
it's look like you have problem with dvd isnot showing in windows explorer / dvd driver.
Try this step from microsoft http://support.microsoft.com/KB/314060
basicly just update (delete some key) the windows registry and restart. ussually this work ok.
Jul 31, 2008 | Toshiba Satellite P105-S9722 Notebook
DVD drive malfunction
Yes, you need to find your local ASP. You can ship it in to us too if you'd like. We're an authorized ASP. This is a VERY common problem in the A205 series. Let me know if you require any more details. By the way, mailing the laptop in might take some time, I'd check with your local ASP (hopefully there's one local to you) and have them order it if possible without having you leaving the laptop there (some ASP's will be ok with that option, we are at times). You will need to provide your laptop part number (starts with PSAxx-xxxx) & serial number and machine has to be under warranty.
advice: extended warranty ;) but i think it's too late now.
Jun 15, 2008 | Computers & Internet
I wish to download the Software drivers for Pioneer DVD RW
May 24, 2008 | Computers & Internet
dear jnstreen,and Ifountain 127 both of you have the same promblem for jnstreen sounds like to me your system has bump your cd rom Try Http://www.slysoft.com it is very goood software
for a dvd you can download and try it for about 21 days and if it works it cost about 39 dollars or so it is wonderful for download
dvd's rewriteing movies almost everything ....It is little to hard for you to uninstall the dvd player and reinstall it if that slysoft.com doesn't work get back with me ok lala linda ifountain127 I am not sure what's going on with your pc have you tried uninstalling it ?
there should be one screw inthe back of your pc to unistall the cd
rom I would try uninstalling it first and all software ) reboot it now go to your dvd player from my computer click on dvd player scrow down to propertiesgo into your properties go to hardware then on the bottom properties again then properties again then to driver
then click on roll back to previous driver and it should work ...if it doesn't let me know lala linda we can try something else ok
Apr 24, 2008 | Toshiba Satellite P105-S9722 Notebook
PIONEER DVD-RW READS ONLY DVD BUT NOT CD
The CD laser has got dirty or failed
Try a driver cleaner if that does not work
replacement drive required
Nov 18, 2007 | Compaq Presario Notebook
http://support.microsoft.com/kb/929461
I had a similar problem with my P205D-S7454. The registry fix worked for me.
Oct 23, 2007 | Toshiba Satellite A205-S4607 Notebook PC
Toshiba Satellite A135-S2246 Notebook Logo
151 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
