Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Library inclusive in archive
Init: deps-module-jar: deps-ear-jar: deps-jar: library-inclusion-in-archive: C:Documents and SettingsPseudoMy DocumentsNetBeansProjectsloginbprojectuild-impl.xml:494: Warning: Could not find file D:etbeansNetBeans 6.0.1ide8modulesextmysql-connector-java-5.0.7-bin.jar to copy. BUILD FAILED (total time: 0 seconds)
how can we solve this problem  i did copy the mysql connector jar file to the right place which is given but problem not solve
    Dedicated:
    Visited the website for 20 consecutive days.
  • 90 Answers
if this is a web-project then you also need to provide the same jar path in the *build.xml* file under classpath variable, whenever the project is built, the classpath is taken from the build.xml file to refer to the libraries.
Hope this helps.
Thanks.
Posted on Apr 27, 2009
How to delete kindle book from I pad
To remove books from ipad:
"In cover view: Tap on the cover for the title and hold it until the "X" appears on the cover. Then tap on the "X" to finish deleting the title. In List view: Swipe your finger across the title toward the left to display the Archive or Delete button. Content that is purchased from the Kindle Store is archived and can be re-downloaded at any time; sideloaded content and personal documents that are not archived in your Kindle Library are permanently deleted. Tap Archive or Delete to remove the book from your Home screen. Archived content will remain in your Archived Items."
Dec 14, 2015 | Tablets & eReaders
My Nook Library has disappeared on my Nook-how do I restore it?
Download all the archived and unarchived books and save them to your computer. Never deleted these.
You have two options for the archived books.
Un-archive them and they will appear on your nook and download as you see fit.
OR... Sideload them. Which is probably what you did before since archived books already disappear from your My B&N Library and would have had to be in your My Documents Library.
Not exactly sure what you mean by 'does not go to my nook' when you try and save/download from the website.
If still having any kind of issue then you can take nook support from experts or call nook help number.
Mar 24, 2013 | Barnes & Noble nook color eBook Reader
Engine oil capacity? mb 300e ?
Engine oil capacity is 6.0 liters, (inclusive oil filter).
If the car is 4matic, (4 x 4), then oil capacity is 6.5 liters, (inclusive oil filter).
Mar 08, 2010 | 1987 Mercedes-Benz 300-Class
I have a problem with **** inclusion in my welds. I am using 3/32 6013 electrodes on a small AC unit. I am welding 1/8 inch mild steel plates in a 2F configuration. When I start the weld I produce is...
A number of things can cause "****" inclusions, poor Technique, bad fit up, Amperage too low, Electrodes damp---etc. Firstly you are using AC-- Check the Electrode carton for the correct ampage, then check the set up, this is the electrode use AC or DC, most 6013 work better on AC terminal setting dont matter + or -- earth.
If you weave too wide you will loose the fluidity on the weld metal, meaning you will be welding over the ****.
before welding the bead, start and iniciate the weld pause a second until the arc is established then move off.
Jan 08, 2010 | Welding Tools
Use digits to complete the two different 6 - digit numbers each number has 7 units, 3 thousands, 9 hundred thousandss and 1 ten answer: _ _ _ _ _ _ _ _ _ _ _ _
Solve the following equation, for X between 0 and 9, inclusive,
and for Y between 0 and 9, inclusive:
7*1 + 1*10 + x* 100 + 3*1000 + y*10*1000 + 9* 100*1000
How many different answers are possible:
(a) none
(b) 10
(c) 20
(d) 99
(e) 100
(f) none of the above
Nov 29, 2009 | The Learning Company Achieve! Math &...
Need help with rounding up decimals
The general rule for rounding of decimals and numers is as follows;
If the number is 1 to 4 inclusive then it rounds down to 0
if the number is 5 to 9 inclusive then it rounds up to 10 then carry the 1 along 1 place to the left
Take a look at the following link for more details and some examples
http://www.dtc.dla.mil/qa/RR.htm.
Oct 01, 2009 | The Learning Company Achieve! Math &...
Warning: include_once(C:\Program Files\xampp\htdocs\joomla\Joomla_1.5.12-Stable-Full_Package/modules/mod_acctexp_language/english.php) [function.include-once]: failed to open stream: No such file or...
This is shown when you log in to Joomla? Did you just install the module acctexp?
My guess is that the permissions are incorrect in the modules folder. try setting the r,wr,ex to all open recursive and see if it lets you run the module.
I will await your feedback
Joe
Aug 13, 2009 | AEC Software Details 3.0 for PC
I can't open my ebook library
Here are the instructions by solving this problem:
1. Right Click My Computer
2. Click Properties
3. Click System Protection
4. Click Advanced
5. Under Performances Click Sittings
6. Click Data Execution Prevention(DEP)
7. Click Turn on DEP for all Programs and Services except those I select
8. Click add
9. Under File name: type in ebooklibrary.exe click open.
Make sure that while doing this process your Portable device is connected to the computer. otherwise you will get a message telling you that ebooklibrary.exe file not found. it took me a while to figure this out. I hope that this will help.
Jan 10, 2009 | Computers & Internet
CODE FOR TV
These might not match your exact philips remote, but may solve problem anyway.
(These are for PMDVD6 aka CL015)
All you really need?? ---> Code Sheet is Here (with entry instruction on far left of first page): http://web.archive.org/web/20050326012352/www.gemini-usa.com/gemini/PDF/Remotes+NA.pdf
One Manual version downloadable from Here: http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pmdvd6-manual2.zip&area=other
All-inclusive scanned manual, codes, retail information card version downloadable from Here: http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pmdvd6-manual.zip&area=other
Dec 14, 2008 | Philips Magnavox Learning Universal Remote
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
177 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
