As you know this rear projection TV has 3 CRTs to produce colored picture and I'm afraid that CRTs got weak in result and causing incorrect / inappropriate colors as you mentioned above.
Red gun seems more weak then other green and blue guns.
you can slightly improve colors quality by adjusting Gain of all 3 CRTs but it requires expertise because you need to go in to service mode of TV. service manual has details about adjustment.
Please do not expect sharp colors performance from ten years old TV, what ever brand.
Hit "add a comment" button for further query / info.
Thanks.
Firstly check if it is TV or set top box issue, by connecting a dvd player and try play something.
If still you face the same issue convergence is out...
This is a common failure with Hitachi sets. Actually, you were charged a little less than most - which usually runs around $400 to fix up the convergence system.
You could probably do the replacement by yourself.
First, go to the owners manual and make sure you have gone through the convergence set up. When pushing the magic focus button be sure that the set does inaugurate the convergence routine.
Your model has hundreds of parts listed at the www.partstore.com site, find the part number on the case of the convergence ICs and search for it. They cost around $30 to $50 each and there are two of them of the same part number (usually). They must be mounted with great care.
Let me know the status ..... Kevin.
Kindly rate this answer.
Hi Kevin
I'll try that when I get back to the house next week. But we did the convergence last night and it did not give any errors and I do not know what part we are supposed to replace.
I'll get back to you regarding this next week once I try the solution.
How do we change to get more red into the TV-is there a control for that and where ?
Regards
Rajesh
H Kevin
I'll get back to you next week.
I don't think I'll be able to change the Convergence I'll have to get someone else to do that. I thought there could be an adjustment which can be changed by programming.
Regards
Rajesh
Not really. We had to get someone to come adn fix the problem
