Question about SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal
Hello I have a simpletech 1TB hard drive and its been working fine. now it says i need to install the drivers for it.
  • 20 Answers
Just go to the simple tech website:
http://www.simpletech.com/support/support_downloads.php
and continue from their
Posted on Apr 16, 2009
Hallo. My simple drive hitachi 1TB 96300-41001-170 dont appear in my computer. I need driver but i cant fint it.
This should be plug-n-play. Have you tried restarting the computer with the hard drive plugged in? If that doesn't work, I would return it.
Apr 14, 2011 | SimpleTech 1TB SimpleDrive Pro Duo...
SimpleTech 1TB External Hard Drive Silver My hard drive suddenly quit working. I plugged the hard drive in and powered on and the white power indicator light came on then just started flashing. The...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jul 25, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
How do I use my simpletech external hard drive. I
I have a 500GB and a 1TB. Both drives if they work at all, is because you have to apply the power after usb is connected. The 500MB still good but the 1TB took a big dump.
Dec 31, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
I have 1TB simpletech drive. was working fine ecxept today. the msg is that this drive is not formated and needs to be. How can I recover my files?
Hello
My apologies if this message finds you long after posting this problem , but I am currently working through a backlog of problems that never got answered and hopefully this info can still be of use if not now possibly in future.
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory disk / hdd to the computer , run the program.
On the program , select the dig deep option for accidentally deleted files or dig deeper for a formatted drive. Then select the disk you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the data was lost. Save the files to a location on the computer hard drive and not back to the disk it is recovering from as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Nov 01, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
I lost my driver cd.so how can i install driver for xp (sp2 or sp3)
http://www.simpletech.com/support/support_legacy.php You should be able to download the drivers for that device at the link, and make a backup copy if you have a cd burner.
Aug 15, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
I have a simpletech 1TB ext. hard drive BOM No.
You need to install the hard drive driver for the PC to recognize it. If you don't have one, just look in the internet for a free driver.
Regards,
Jeep Brainy
Aug 14, 2009 | SimpleTech 1TB SimpleDrive Pro External...
Good Afternoon, I have an 64bit HP Pavillion System, brand new, with Vista Home Edition, I previously purchased a 1TB USB external HD Simpletech, works fine with XP, but not with vista, keeps looking for a...
there have been alot of problems in the past with vista not all external components are compatible with this program.i had the same problem with vista so i got rid of vista and started using windows xp home edition since then i have never had a problem with it not recognising any device i have added to my computer.i hope this helps.
May 06, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Computer wont recognize external drive
The simpletech 1tb drive's case has issues. I had the same problem. It actually quit while I was running a video off the drive. I replaced the case by removing the harddrive from the one it came in and installing it in another case and now it works again.
The first thing I would try is installing the drivers it came with, but failing that you will need to replace it's case.
It has 4 screws to remove, 2 under the silver warranty voiding tape and 2 visable on the bottom side. Remove them, then use a flat screwdrive to pop the case open (gently). Then remove the harddrive.
You will need a case with SATA data AND power cables for this to work.
Sep 26, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal Logo
802 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
