Cars & Trucks Logo
Posted on Apr 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine knocks when startup but disappears after engine warms up.....could the oil pump be defective.......what about the knock sensor....
Anonymous
Level 2:
  • Expert 507 Answers
  • Posted on Oct 22, 2009
Anonymous
Expert
Level 2:
Answers
507
Questions
0
Helped
187089
Points
957
Its probably lifter noise,check what grade of oil is in the car or change it to a slightly thicker grade,i would expect that the car has a lot of mileage on it,if the oil light goes out quickly on the dash when starting its not the oil pump(very uncommon),knock sensor is for ignition timing to stop pinging,nothing to do with your noise,generally its engine wear
Chevrolet Uplander 3.9L intermittent knock until warmed up
could it be a high pitch knocking like a ticking-this would be a lifter thats not pumping up right any-it may be time for oil change to winter oil-5w20-oil change could help anyway-cheers Denny
Cold knock (then Subsides)
sounds like a crushed valve lifter
Engine knocking
engine knocking sound like worn engine bearings or low oil level. if oil level okay more likely oil pump has failed or engine bearings worn out or engine oil diluted with antifreeze or gasoline causing viscosity oil to be too thin.if oil and filter been changed.if you see check engine light flashing code scan for faulty knock sensor. if you see low oil light flashing engine knocking damaged to engine done.
2answers
Car is knocking and was low on oil cold it be the knock sensor out no oiland water mix in the oil
did the oil light come on? it it did that means a low pressure situation which can cause con rod bearing damage. the knock sensor can cause that too.
5helpful
2answers
How to repalce a knock sensor on my 2004 gmc yukon
Hi welcom to fixya. A defective knock sensor may cause engine detonation or reduced spark advance and fuel economy. When a knock sensor is removed and replaced, the sensor must be tightened to its specified torque. If the knock sensor is installed tighter than it should be, it may become too sensitive and provide an excessively high voltage signal, resulting in more spark ****** than required. When the knock sensor is installed looser than it should be, the knock sensor signal will be lower than normal, resulting in engine detonation.
To replace the knock sensor:
  • Disconnect the knock sensor wiring connector.
  • Then, unscrew the sensor.
  • Remove the knock sensor.
  • Reverse the procedures to install the part.
  • 15 ft.lbs.torque
  • hope this helps.Thank You for using fixya..iluv2fish.. Ray..
1helpful
4answers
When I start my car I hear a fast knocking noise from the engine. my oil is fine. as the car warms up the knocking diminishes.
You have either worn out connecting rod bearings or a weak oil pump it is possible the oil pump pick up screen is clogged.
I have a 1994 Subaru Legacy and It has started making a "knocking sound". Cked the oil, it was OK
knocks when cold ( Start ), then sort of diminish or disappears when warming up ???
Knocking goes faster when accelerating when cold ???
If Yes, then Piston knocking on the wall of the cylinder . The sound disappears as the engine is getting warmer it dilates and the gap gets smaller.
If this just started,
1. Put quality oil & filter ( Mobile Full Synthetic Oil & Mobile Oil Filter or Purolator )
2. Do not put cleaning agents mixed with oil.
3. Personaly i've put "Restore" Engine Restorer & Lubricant in cars with more then 200 000 km and the results are amazing. But only "Restore". My Volvo is at close to 300 000 km, and it runs great. It's not a cleaning agent.
By experience if the knocking just started you can put an easy extra 100 000 km on the engine before a rebuilt. Quality Oil & let the engine warm up ( 3 mins ).
1helpful
2answers
96 Suburban v8/7.4L/454 K2500, Knocking Noise??
sound like an internal engine problem. either one or more of the pistons has "piston slap" and that knocking will diminish as the engine warms up or possibly a rod bearing is worn out. have a tech do a manual oil pressure test to make sure the oil pump and main bearings are ok. piston slap or knock that decreases when the engine warms up is not that serious, but a rod bearing knock or possible oil pump failure should be taken care of asap.
2helpful
1986 jetta oil pump location and replacement/knock sensor
oil pump is in the oil pan and if you have no or low oil pressure replace pump before doing anything with knock sensor. knock sensor is more or less a microphone and listens for spark knock but will set codes for any knocking or tapping noise which is commonly heard if oil pump is malfunctioning
Top Datsun Experts
ZJ Limited
ZJ Limited
jws1013
Are you a Datsun Expert? Answer questions, earn points and help others
