I need an instruction manual
I have lost my manual and wondered if i could pleaase have anoather one. I want to lift out the plastic soap despensing box to clean it and am not ssure what to do
Water real slow in filling up the bowl seems like a clog, need to know how to lift the lid and take off the cold water intake to see if anything is blocking flow
Posted on Apr 16, 2009
Soap does not despense and h20 keeps coming up.
something wrong with the water inlet
perhaps the washers valves or filters
Dec 09, 2014 | Hotpoint Washing Machines
Looking at machine top left side in back leaking out of little vent
If its water you may have to lift the control housing and look underneith, there are soap despensing water valves there, thet could be leaking
Sep 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The smart soap dispenser on my GE profile dishwasher is not dispensing soap. I filled the smart dispenser several months ago and it does not appear that any of the soap was dispensed. how do i resolve?...
We mistakenly switched liquid detergents and mixed enzyme based and bleach based. They gelled in the dispenser. I took the outer door cover off and could not figure out how to take the white plastic despenser off of the main door without breaking it. I disconected the electrical harness and took the main door off the hinges so I could take it outside, turn it upside down and use the garden hose pressure nozzle to blast the gellout of the white plastic dispenser. I use a piece of plastic coat hanger to poke around inside to break up the gell several times. It all came out in marble size pieces.
Aug 17, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Soap despenser+will not dispense soap.
Hi. WHen a soap dispenser will not dispense soap it is generally because of one of two things. Either it is clogged or the soap you are dispensing is too thick and needs to be diluted a little with water, or possibly both. J.
Aug 07, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
Leaking
Could be that the despensing tank has melted and deformed at the connection point. This is what happened to me when I put in really hot tap water. The heat allowed the connection (where the water/soap outlet is) to deform when using it. Now when I fill the tank and place it in the machine the water just leaks out all over the place with no control.
If you look at the bottom of your tank, where the water comes out, you may be able to see that the plastic is mis-shaped or deformed slightly. It probably doesn't take much for the seal to be broken.
TEA
Sep 22, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Soap
As you look at the despenser drawer it has 3 chambers. The left chamber is for Prewash detergent, middle for Fabric conditioner, right is for Liquid or powder detergent. Or use a plastic ball in the main drum!
May 05, 2008 | Hotpoint Ultima WD72 Front Load...
Soap dispenser
I got my fixed last night. It was the "lid" for the softener despenser that was making the drawer stick. To remove it you need to take the top off of the washer. There is are two plastic "holders" on the back of the machine that hold the top onto the machine. Each of these "holders" have two screws, remove them, then remove the holder. You can then, with some effort, slide the top of the washer towards the back the then lift it off. You will then be able to see plastic tub that contains the drawer for the despensers. You can't remove this tub, but on the side facing the inside of the washer are a couple of tabs holding the top of the plastic down. You can gently release these tabs and pull up on the top slightly. This gave me enough "play" to then open the drawer. The problem, I believe, is that over time, that tub moves and makes it impossible for the drawer to open. With trial and error, I found that with removing the "lid" for the softener despenser, and completely closing the lid of the plastic tub, that that solved the problem.
Sep 03, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
