Home | Sharp | AL 800 Grayscale Copier | Blinking letter L
Sharp AL 800 Grayscale Copier
Problem for Sharp AL 800 Grayscale Copier
Blinking letter L
By greisser on Apr 16, 2009
Blinking letter L
Solution #1
posted on Apr 17, 2009
Not Rated)
hinderschied
Rank: Guru
Rating: 92%, 41 votes
The scanner probably got locked. If you reach up under the scanner in the cavity where the copies come out, there is the locking mechanism. turn it 90 degrees to unlock it. turn the copier off and then back on to clear the code.
Was this helpful?
Yes
No
Popular Solutions for Sharp AL 800 Grayscale Copier
Questions and Unsolved Problems for Sharp AL 800 Grayscale Copier
Do you recommend Sharp AL 800 Grayscale Copier?
Answer
Answer
Printer is printing a small test pattern when we print a page it appears in the upper right hand... (More)
Answer
ink system failure. What can I do to get it working again. I tried the power shutoff idea and it... (More)
Answer
fellowes c220 shredder jammed-- got some of it loose- now can't see it jammed document or get... (More)
Answer
text comes out fuzzy and unreadable
Answer
The copy has several big strips of ink in the middle
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL 800 Grayscale Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
