Question about NorStar CallPilot 100 Voice Mail, 10 mail boxes - Answering Machine
Call Pilot voicemail Nortel
We need to block the callers from dialing direct to ext from the voicemail. they only need to dial the single digit optons not the ext. numbers
  • 105 Answers
Sorry, not possible. In fact, the AA greeting tells callers "If you know your parties ext., you may dial it at any time".
But, you could turn off the AA greeting and change your greeting (ie: Greeting #1) to say something like:
"Thank you for calling ABC Company. Please listen carefully as our menu options have changed."
You could go so far as to change your employees ext. #'s (using Change DNs in system programming), so that callers will not know the extension numbers and will have to use only the menu options you provide.
Hope this helps!
Posted on Aug 11, 2010
    Problem Solver:
  • 9 Answers
Depending what number your extensions start with, you need to go to the programming for the auto attendant and "undefine" the number in the menu. More than likely, it is built as a "thru-dial" and allows callers to punch in the extension. If you remove this, callers will have no other choice but to use the options in the menu. I can walk you through these changes if you want.
Posted on Aug 04, 2009
DTU-16D-2
Voicemail is usually ext 200 or 300 if it's not assigned on a speed dial button. If your ext has a mailbox assigned the voicemail will greet you or ask for your code. If you don't know the code your voicemail administrator will have to reset the password or mailbox. If your ext doesn't have a mailbox assigned, then it will just give you the main greeting that outside callers get.
Jul 07, 2014 | NEC Lands Phones
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
How do i transfer a call with my norte t7316e
There are 3 Flexible Feature buttons under the horizontal display. When you are on a call, the display will show "Transfer" over the last button. Press that button, which will automatically put the caller on hold, pick up an intercom and prompt you to enter the extension to transfer the caller to. Enter the ext. number and tell your employee who is on the call, and heng up - the caller will be connected automatically. Or, after dialing the ext. to transfer the caller to, just hang up and the call will ring through. Good Luck!
May 05, 2010 | Nortel T7316E 2-Line Corded Phone
Setting up the Voicemail on a Nortel T7208
your mailbox number is the last 4 digits of your phone number
Apr 26, 2010 | Nortel Business Series Terminal T7208 -...
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
Sep 30, 2009 | Nortel Business Series Terminal T7208 -...
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
Need to forward to voicemail without phone ringing.
Transfer to voice mailbox: Feature 986, dial ext. number of phone and release. Call is transferred to mailbox without ringing the phone.
Mar 09, 2009 | NorStar M7310 Corded Phone
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
DKT's wont ring from transfer
put an "H" after the extension in the voicemail, i.e. 200H, you have to put in your #656 #657 codes into the phones to integrate the voicemail. #656 91, ext of voicemail pilot, hold #657 92, ext of voicemail pilot, speed dial button (program one on the phone if it doesnt already have it), enter the number of seconds before the phone should forward to voicemail, i generally do 16, hold. that should fix that!
May 22, 2008 | Toshiba DKT-2010 Corded Phone
Lands Phones Logo
295 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
